My draw through turbo
Re: My draw through turbo
My Single S.U HS8 will flow 330 cfm. Plenty.
I'm running a Weber dcoe 40 at the moment and she is running great a little rich when of boost but I need to be a little rich for when boost comes on. I've been looking at the Holly four barrel carbs and if I've got this correct under normal driving I will just be running on two ventruis so I can jet them for of boost driving and then if I go with the vacuum set up not mechanical the other two cents open up when on boost so I can jet them a little richer?
Yes I know EFI is the way to go but I love the look of the draw through set up much better
Yes ,that's correct!,, we all need to go to some 'swap meet's and find Adam a carb,their like "a dime a dozen over here",, as in cheap but I live in a rural area and 'swap's are few & far ,,,
I'm looking at Β£600 plus here in the UK
And a manifold to turbo as well
More than happy to pay postage, the cost of the carb and a nice little tip to who can ever find one of me
Yea that's ridiculous I know I'll keep an Eye out for ya ,
The bug made it to spa, just
But now I have a massive ignition problem
- rubenski
Can we help?
Lots of vw people there to give you a hand!
I'm heading to a car show here in a cpl hours and I'll put up a 'sign' :Lookin for a Holley Carb"cheap,,lol ,,,, hope u sort it out ,,, my points wore and closed up on my bug , an it still ran cheers,
My issue is trying to cruise the ignition is just cutting in and out and when I put my foot down the engine just pops and stops. Also when I start it up it just backfires out the exhaust and will not run on all four plugs for a few minutes then it sorta it's self out
- rubenski
You got the wires going to the correct plugs?
Stupid things first
Stupid things first
Ha ha ha yes mate right leads to right plugs.
My guess is 'Fouled Plugs or bad plug wires? sorry didn't find carb yet
No problems.
Well I've changed all the leads but here's an update Von the random misfire. Now when I get the misfire the rpm gauge also starts jumping aroubd, now the rpm gauge gets its signal from the negative side of the coil so I'm thinking is something earthing the coil causing the rpm gauge to jump around and the plug/ plugs to miss?
- rubenski
