Thick wall B+P's, your experiences please?
Moderator: seabeebuggy
vwjim
Post by vwjim » Mon Jul 24, 2017 10:04 am
Hi,
I've a few T1 engine cases + heads cut for 94mm B+P's, but I'm considering using the thick wall B+P's to build an 1835cc split bus motor.
Main reason for the reduction from 1914cc to 1835cc is so I can build the engine with Mexi EFI hardware, with the possibility to supercharge it at a later date.
What's the generally thoughts on the quality of the thick wall B+P's as I've never used them before? And secondly, are they okay for a low pressure supercharged engine if I go that route?
Thanks.
Jim
Clonebug
Re: Thick wall B+P's, your experiences please?
Post by Clonebug » Mon Jul 24, 2017 7:41 pm
I have been running AA TW 88mm barrels and pistons for 3-4 yrs now. I have probably 25.000 miles on them boosting 17-23 lbs.
The one thing that will get them is detonation....keep that under control and they hold up well even with non forged pistons.
vwjim
Post by vwjim » Tue Jul 25, 2017 12:36 am
Excellent. Thanks.
Mine would be a very mild boost level, so much less stress than yours. So good to know the AA's have held up with that mileage you've done.
