First time turbo build
Re: First time turbo build
Thank you kenric
- kangaboy
Meh, close enough
- kangaboy
Ha, I'm just playin.
Did you figure out anything with your routing of fuel lines? FWIW, I actually ran two separate fuel lines to make mine work. They both come through the front firewall down by the passengers foot area, and run along the outside of the tunnel (inside the car) to under the back seat. I crossed them over the tunnel from the passenger side to the driver side under the back seat, and then drilled two holes and sent them out the back. I believe there is actually a diagram in the Bentley that describes how to do it. Anyway, after I had both of my lines ran (needed two, because when I initially got the car, the original line was already clogged beyond repair), I purchased This Tee and several male hose barbs.
The top feed comes from the fuel tank, and then one port goes to the fuel pump followed by the filter to the motor, and then obviously the return line from the motor goes to the last open port (return port).
With such high pressure running throughout the system, it seems like it may not work right, but folks have been running it like this for quite sometime, including myself. No noticeable hiccups as far as I can tell
I installed a cb tee for the tank. As for the fuel line thankful my original line is good so i only needed to run one additional line. I ran it thru the tunnel out the back towards the passenger side and out the front on the drivers side. I'll try and get some pictures tomorrow.
Actually the passenger side front has more room to install a pump and filter.yellow_snocone wrote: ↑Fri Jun 16, 2017 8:21 pm I installed a cb tee for the tank. As for the fuel line thankful my original line is good so i only needed to run one additional line. I ran it thru the tunnel out the back towards the passenger side and out the front on the drivers side. I'll try and get some pictures tomorrow.
The drivers side has the Master Cylinder and reservoir in the way.
Clone ill be mounting the pump and filter on the passenger side i just ran the supply line to the driver side.
Mounted the cb T New supply line going to the driver side Added some extra security Ran the line out the back towards the passenger side Replaced some of the old line to match the new sized line
You may need to change one of the barbed fittings in the tee on the tank for better supply to the filter and pump, the better the flow, the less pump issues you will have
I am using a 1/4" to match the existing line and a 5/16" to match the new supply. The pump i got uses 5/16 connectors should i replace those for 3/8 or bigger?
I'm setting up mine currently, 5/16 supply and return hardlines and a 1/2 supply from the tee to the pump. The efi roller cell pumps don't suck very well, so the less restriction from the tank to the pump the better, by all means try the 5/16 but be ready to possibly up size for better flow
I'll look into whether my pump has issues with 5/16 or not. Thank you for bringing that to my attention66brm wrote: ↑Mon Jun 19, 2017 3:36 am I'm setting up mine currently, 5/16 supply and return hardlines and a 1/2 supply from the tee to the pump. The efi roller cell pumps don't suck very well, so the less restriction from the tank to the pump the better, by all means try the 5/16 but be ready to possibly up size for better flow
Time to install my kafer bar. Gotta order a few things then i can begin wiring and getting the engine together.
- buguy
Where did you get your bar?
- Chip Birks
Its this one I believe.
Chip Birks wrote: ↑Wed Jun 14, 2017 8:10 am I use this one. I have the 1 inch version. Seems to work pretty well.
http://www.kustom1warehouse.net/Bolt_on ... 7-2975.htm
Yup it's the one chip posted the link for.
