First time turbo build
Moderator: seabeebuggy
yellow_snocone
Re: First time turbo build
Post by yellow_snocone » Mon Sep 11, 2017 8:56 am
3 wires and the ground is going to the relay board. I wired it based off of Mario's wiring guide on his webpage. How should i test the resistance?
Each time i have calibrated it the difference between the closed to wide open has been different. Typically being a 60 count difference. The screenshot shows the closet count difference.
Clonebug
Post by Clonebug » Mon Sep 11, 2017 8:24 pm
Are you sure you have the TPS clocked correctly???
yellow_snocone
Post by yellow_snocone » Mon Sep 11, 2017 10:35 pm
Hmm that's something i need to look into. It came installed in the throttle body so i didn't think much about it. Ill test the resistance and make sure it's clocked correctly.
yellow_snocone
Post by yellow_snocone » Thu Sep 14, 2017 8:42 pm
I got a chance to hang out in the garage and tested my tps wires and i think i know why i cant calibrate my tps in tunerstudio. I tested the plug coming from the relay first.
Here is my ground reading
Here is my power supply. Just shy of 5 volts
And here is the problem... I'm getting a steady follow of .21 volts.
From my understanding of what I've read online i should be getting close to 0 volts. What could be causing this?
I didn't get a chance to check my tps position but will definitely make sure it's clocked properly after this fix
