Turbocharged 1600
Moderator: seabeebuggy
Re: Turbocharged 1600
Post by advinnie » Thu Sep 28, 2017 2:31 pm
Ha ha ha no my plans have totally changed now I'm now using a Weber dcoe 40 on a draw through set up with a air search (T3) turbo and yes I did have a boost leak it was one of the manifold boots so change that and am seeing 12psi boost in 4th at 3800rpm but I've had to drop the boost level down cause the stock clutch is fine up to 9psi but starts to slip after that 😡
