Hi guys.
If I was to boost reference a fuel regulator and take a signal from the CARB HAT, would I need to fit a ONE WAY check valve.
Like is there any vacuum on closed throttle plates with a small hole drilled in the plates to get my idle speed at 1k revs.
I've drilled the plates to make sure no progression holes are exposed on my dells.
vacuum
Re: vacuum
No vacuum in a carb hat on a blow through system. No check valve needed. Good call on the progression holes.
- Leatherneck
Re: vacuum
Any pics of the holes you drilled?GARRICK.CLARK wrote:Hi guys.
- seabeebuggy
Re: vacuum
You need to get vacuum from below the carb.
Re: vacuum
No pics , the holes in the throttle blades are the same as what are drilled into old solex carbs
- Leatherneck
Re: vacuum
GARRICK.CLARK wrote:No pics , the holes in the throttle blades are the same as what are drilled into old solex carbs
Do you remember what size hole you drilled?
Re: vacuum
Somewhere around 2 mm. So what I did was to back off the throttle stop, then turn it back in till it just touches the throttle stop. drilled holes in plates like on old solex carb. Warm engine up and see what idle speed you have. If idle is too low drill your holes up half a mm. Its a trail and error thing.
Set your timing at 10 BTDC.
I have my BOV piped into the manifold below the throttle plates.
Boost gauge and Fuel reg. piped into the top of the carb hat
- Leatherneck
Re: vacuum
I have Boost gauge, and BOV going to intake manifold, Fuel Reg and Wastegate coming from Turbo manifold. Thank you for the info on the hole size and adjustment.
