CARBON SEAL
Moderator: seabeebuggy
rs58rag
Re: CARBON SEAL
Post by rs58rag » Wed Jul 19, 2017 12:38 am
I have a draw through 1914cc with a Holset hx30 turbo and it pulled oil into compressor side on first attempt. Now oil line has .078" restrictor and big 3/4" ID oil drain and I used new oil seals, o-ring and compressor seal collar from rebuild kit, no smoke whatsoever now. You must have a good size, non restricted oil drain.
madmike
Re: CARBON SEAL
Post by madmike » Wed Jul 19, 2017 5:21 am
I don't thing my E-bay china turbo :oops: has a carbon seal and It don't smoke , has a bit of oil in the intake when I check but still no smoke,lol
rs58rag
Re: CARBON SEAL
Post by rs58rag » Wed Jul 19, 2017 11:59 pm
Took out .078" oil restrictor and put in .062" again. Wanted to see how far I could go and .078" was the limit, still no smoke. 26mm oil pump, Rotella 5-40 full synthetic oil.. Still running 40 dcoe and best change was 200 air, 165 gas, f11 et, .65 pump jets 60/65 idles with 30 venturis.
Udo Airbus
Re: CARBON SEAL
Post by Udo Airbus » Thu Jul 20, 2017 4:49 am
Ah thats good info thanks!
VW T1 1964 - Mouse Grey - Pearl White OG paint
Bagged, Porsche steeringrack/brakes..IRS, AMR Supercharged 1600 (sold) building a 1971cc EFI turbo/supercharged engine
petew
Re: CARBON SEAL
Post by petew » Thu Jul 20, 2017 6:14 am
Just reading through this thread. Restrictors in the supply line are really important on aircooled VWs. We run a lot of pressure, especially in the gallery where the sensor is. Half of my issues with oil leaking past the seals were cured with restrictors.
buguy
Re: CARBON SEAL
Post by buguy » Thu Jul 20, 2017 7:30 pm
In was reading somewhere that some guys actually use Holley carb jets to restrict flow. I guess so they have a size to off of. I'm not real sure where they put them though.
rs58rag
Re: CARBON SEAL
Post by rs58rag » Thu Jul 20, 2017 11:46 pm
Lot of blow through water pumper engines using turbo oil restrictors because of too much oil volume at turbo center cartridge causing oil past seals. Some of those engines are revved past redline with high boost and have kept the turbo oil volume managed with an oil restrictor and good turbo oil drainage.
madmike
Re: CARBON SEAL
Post by madmike » Fri Jul 21, 2017 5:51 am
I have a "weber' jet in one of my turbo's
rs58rag
Re: CARBON SEAL
Post by rs58rag » Fri Jul 21, 2017 9:01 am
I tapped -3 an fitting and locktite a 1/4"x1/4" stainless set screw then drilled .062" hole.
rubenski
Re: CARBON SEAL
Post by rubenski » Sat Jul 22, 2017 8:27 am
How does one detetmine the right size of oil restrictor?
rs58rag
Re: CARBON SEAL
Post by rs58rag » Sat Jul 22, 2017 8:33 pm
Trial and error here. Tried -3an oil line to Holset hx30.... smoke off boost.... Ran .062" oil restrictor .. no smoke, ran great. Tried .078" oil restrictor and started getting small film of oil past seal evident on spark plugs. Back to .062" restrictor..... I've noticed most restrictors in .035", .040" for ball bearing turbos and .060", .065", .075" available for journal bearing turbos.
rubenski
Re: CARBON SEAL
Post by rubenski » Sun Jul 23, 2017 2:51 am
And does every turbo has a restrictor on from stock or do you have to fit one your own?
Re: CARBON SEAL
Post by Piledriver » Sun Jul 23, 2017 4:09 am
The OE factory feedline might. Nobody uses that most likely.
petew
Re: CARBON SEAL
Post by petew » Sun Jul 23, 2017 5:17 am
The barrel bolt oil for the oil feed on my turbo has a 1.5mm restrictor hole from the factory. I added another 1mm restrictor where the T-piece comes off the block. That is using a ball bearing turbo though.
rubenski
Re: CARBON SEAL
Post by rubenski » Sun Jul 23, 2017 5:27 am
Thx for explaining!
