Homebuilt water meth kit
Hi guy's, I want to build a water meth kit for my turbo setup on a 2.1 wbx. I want it to be boost activated at around 5 to 6 psi. I'm using T3T4 blowing through twin 40 Dellortos with charge cooler. Any ideas as to what to use and how to test/build would be greatly appreciated,
Re: Homebuilt water meth kit
Do you actually need a water/meth kit at 5/6psi?
What is max boost?
What is max boost?
2165cc on a Borg Warner S257 SXE, DTA S60 on E85.
Boost was created only to make people smile, and make power!
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
10.221 @ 135mph SCC2018
Hi bug66, I'm boosting 10psi, still playing with the idea so I thought if you're going to drag it, it might as well start pumping at about 6 psi and keep going till you reach 10psi or more.
- Chip Birks
Talk to clonebug on here. He had a pretty simple and effective setup on his buggy.
- risk
Most guys around here doing homebuilt meth kits end up blowing their mobile homes sky high..
Do a google search for "hobbs switch" .. some are preset to make a connection at a certain psi, others are adjustable. One of my turbo buick buddies had a similar rig on his car. he was pushing 30psi and 600+ HP. His setup came on at around 15psi with two #10 nozzles. The hobbs switch energized a relay to the pump.
Adjustable Hobbs switch:
Also you will need a pump, tank, nozzle and misc plumbing.. as well as a check valve at the nozzle so it won't drip.
The nozzles are available from McMaster carr here:
http://www.mcmaster.com/#spray-tips/=12kxxml Full cone misting nozzles 1/8npt.
Check valve:
http://www.mcmaster.com/#check-valves/=12ky2q7 Brass check valve 1/8npt.
Sizes are commonly referred to at their 100psi flow rate. I would start with a size #5, or #10 and go up or down from there. Too big will bog the motor hard once it starts spraying.
Check valve:
Those nozzles are rated at gpm which is way too much flow for a W/I system.
I run a 2.0 gph nozzle for my hp rating. I actually have two nozzles now for a combined flow of 3.0 gph.
- bad62bug
Flow Rate, gph
Each
Each
Each
Pipe
Size 40
psi 100
psi 500
psi Orifice
Dia. O'all Wd.
(Hex Size) O'all
Lg. 1-9 10-Up 1-9 10-Up 1-9 10-Up
Full Cone
1/8" 0.63 1.00 2.24 0.01" 7/16" 1 1/8" 3178K61 $7.20 $6.40 3178K81 $12.30 $10.94 3178K41 $8.77 $7.80
1/8" 1.26 2.00 4.47 0.01" 7/16" 1 1/8" 3178K62 7.20 6.40 3178K82 12.30 10.94 3178K42 8.77 7.80
1/8" 1.90 3.00 6.71 0.02" 7/16" 1 1/8" 3178K63 7.20 6.40 3178K83 12.30 10.94 3178K43 8.77 7.80
1/8" 2.53 4.00 8.94 0.02" 7/16" 1 1/8" 3178K74 8.29 7.36 3178K84 15.27 13.58 3178K44 10.58 9.41
1/8" 3.16 5.00 11.18 0.02" 7/16" 1 1/8" 3178K75 8.29 7.36 3178K85 15.27 13.58 3178K45 10.58 9.41
1/8" 6.32 10.00 22.36 0.03" 7/16" 1 1/8" 3178K76 8.57 7.60 3178K86 15.82 14.07 3178K46 10.94 9.73
1/8" 9.49 15.00 33.54 0.04" 7/16"
Each
Each
Each
Pipe
Size 40
psi 100
psi 500
psi Orifice
Dia. O'all Wd.
(Hex Size) O'all
Full Cone
Ah.... I clicked on the nozzles that your picture showed which was in gpm.
The misting and fogging nozzles.
- bad62bug
About how much HP?Clonebug wrote:Those nozzles are rated at gpm which is way too much flow for a W/I system.
I don't know but my 32# injectors are maxed out and they support 230 hp at 100% duty cycle. I'm at 95.3 % when I rev to 5800 rpm.bad62bug wrote:About how much HP?Clonebug wrote:Those nozzles are rated at gpm which is way too much flow for a W/I system.
My afr is 12.0:1 at 22lbs boost.
