T4 1971cc - Blow Through Turbo - VW Splitscreen - NEW Movie @ page 13
Moderator: seabeebuggy
Udo Airbus
Re: T4 1971cc - Draw Through Turbo - VW Splitscreen
Post by Udo Airbus » Fri Jul 21, 2017 2:40 am
Ok the starter I got from my brother in law was in a bad shape. So I bought another one at the JunkYard yesterday. From a VW caddy 1.9 TDI.
So I matched the holes, and it fits.. very easy job. My only concern is that it will not fit under the car.. The solenoid is on top, and thats were the fuel tank is located. I was thinking to turn it around but them it will hit the driveshaft. So wel need to make it custom again :lol:
But then , wauw it spins the engine great!
Then connected the ignition, and Fire in the hole! Its starts directly.. (even with the long intake)
Unfortunately my fuel pomp did not arrive yet so I cannot run it long. (I hope i get it tomorrow)
One other issue, the screw thread of the alternator is bad, so I cannot install the belt.. and the oil pressure switch is leaking itself.. (will buy new one)
But wauw it sounds great! even without an muffler..
to be continued!
VW T1 1964 - Mouse Grey - Pearl White OG paint
Bagged, Porsche steeringrack/brakes..IRS, AMR Supercharged 1600 (sold) building a 1971cc EFI turbo/supercharged engine
Post by Piledriver » Fri Jul 21, 2017 2:51 am
If you get one from a std 5 speed TDi etc, its snout is very long, so it would need a thick spacer to work.
(probably around 1")
Good news: The manual starters are ~infinitely more common.
The other good news: with a thick spacer, you could clock it so the solenoid sticks out sideways ~easily.
Bad news is i don't know exactly how thick it needs to be, but you have much more motivation...
Spacer needs to center on the hole in the trans, and have another centering hole on the other end.
It could be welded on flanges on a lathe turned center bit, clock the flanges as needed.
Aluminum best, but mild steel would work.
Udo Airbus
Post by Udo Airbus » Fri Jul 21, 2017 4:05 am
Yes exactly, I can also make the spacer on the outside.. instead between the starter and gearbox...
I will do some measurements with the gearbox and starter only to see how many room we have..
Ah first we will do the camburn :D Hope I get the last parts tomorrow..
Udo Airbus
Post by Udo Airbus » Tue Jul 25, 2017 4:01 am
Ok got the cam burn done, for 14 minutes.
I changed the main jets to 155 and air to 180.. Much better now. But difficult to rev or good idle after revving the engine.
To me it looks like the plenum under the carb is creating this issue. Now some fuel still stay at the bottom. I will remake the plenum that no fuel can stay in there... also will hook up the AFR gauge. + need to fix my Dynamo.. :| :mrgreen:
Udo Airbus
Post by Udo Airbus » Mon Jul 31, 2017 9:36 am
So with new intake it runs much better. Changed Idle to 60 ip 50.. so thats also solved. Only it will not rev smootly , im thinking to lock the 009 at 24 now.. I also run 36 venturi's and think they are to big.. any recommendations? thanks.
Udo Airbus
Post by Udo Airbus » Tue Aug 01, 2017 2:00 am
https://youtu.be/IXS-sNDE-2s
Some evidence, (Fixed:sorry that its on his side..) but i think the sound is more important :mrgreen:
petew
Post by petew » Tue Aug 01, 2017 2:06 am
Well done. So put it in the bus and drive it! :)
Udo Airbus
Post by Udo Airbus » Tue Aug 01, 2017 6:21 am
Thanks Pete! mwaa still much to do.. :shock:
MegaRookie
Re: T4 1971cc - Draw Through Turbo - VW Splitscreen - Movie @ page 10
Post by MegaRookie » Tue Aug 01, 2017 3:15 pm
Nice :D good to see the engine running! :!: Is the revving problem solved already?
kangaboy
Post by kangaboy » Tue Aug 01, 2017 8:12 pm
Oh baby, that thing sounds peppy :)
Gonna be some fun!!
'74 Standard- 1776T, MS3X3
'76 Westy- Stock 2.0L L-Jet
panel
Post by panel » Tue Aug 01, 2017 11:48 pm
Sounds great!
Subaru JDM EJ20 Turbo bus
Udo Airbus
Post by Udo Airbus » Wed Aug 02, 2017 1:59 am
Thanks all!
No, I need to lock the 009.. will do that coming weekend I hope.. :)
buguy
Post by buguy » Wed Aug 02, 2017 5:42 am
Remember you want to limit it to 24* not lock it at 24.
Udo Airbus
Post by Udo Airbus » Wed Aug 02, 2017 7:18 am
Yes exactly! 8)
Since I need to use this 009 also on my 1600cc I need to make it adjustable.
yellow_snocone
Post by yellow_snocone » Wed Aug 02, 2017 8:49 am
Sounds great! One step closer to driving that beast
