T4 1971cc - Blow Through Turbo - VW Splitscreen - NEW Movie @ page 13
Moderator: seabeebuggy
MegaRookie
Re: T4 1971cc Megasquirt turbo - Budget with a lot of torque
Post by MegaRookie » Mon Jul 17, 2017 4:50 am
Hi Udo,
Sad to hear that your starter wasnt strong enough. On my beetle (also 2 l type 4) I used one of a golf. I cant remember the year but it has the following numbers:
Bosch nr 001121006
Vw nr 020911023f
Those are good available on the Dutch scrapjards for approx 25-30 euro's. The only mod you need to do is to (weld and) redrill the holes.
Good luck!
Best regards Mark
Ps. This is what it looks like after the mod.
Udo Airbus
Post by Udo Airbus » Mon Jul 17, 2017 6:38 am
Ha Hoppus Aka Mark from KS !
I was already seaching for your post @ keversite.. lol !
But anyway, cool thanks for the info!
It think it comes from a golf 4 automatic:
http://www.ebay.com/itm/VW-GOLF-SE-MK4- ... 0510485065
My brother in law got some TDI starters, So I will have a look in his garage next wednesday.
(not Ome Sander, but another one, the watercooled diesel man :mrgreen: )
VW T1 1964 - Mouse Grey - Pearl White OG paint
Bagged, Porsche steeringrack/brakes..IRS, AMR Supercharged 1600 (sold) building a 1971cc EFI turbo/supercharged engine
Udo Airbus
Post by Udo Airbus » Mon Jul 17, 2017 6:52 am
Oke they fit (except redrill holes) from:
part no:
020911023F
020 911 023 F
Bosch nr 001121006
WIll fit from models below:
Volkswagen Golf ('97-'04)
•1.4-16V (55 kw / 75 pk)
•1.6 (74 kw / 101 pk)
•1.8-5V (92 kw / 125 pk)
•2.3 V5 (110 kw / 150 pk)
•1.8-5V Turbo GTI (110 kw / 150 pk)
•1.9 SDI (50 kw / 68 pk)
•1.9 TDI (66 kw / 90 pk)
•1.8-5V 4Motion (92 kw / 125 pk)
•2.0 (85 kw / 116 pk)
•1.9 TDI 4Motion (66 kw / 90 pk)
•2.8 V6 4Motion (150 kw / 204 pk)
•1.6-16V (77 kw / 105 pk)
•1.9 TDI 4Motion (85 kw / 116 pk)
•1.8-20V GTI (154 kw / 209 pk)
•3.2 V6 R32 (177 kw / 241 pk)
•1.6-16V FSI (81 kw / 110 pk)
Audi A3 ('96-'03)
•1.8 5V (92 kw / 125 pk)
•1.8 5V Turbo (110 kw / 150 pk)
•1.8 5V Turbo quattro (110 kw / 150 pk)
•1.8 5V T S3 Ambition (154 kw / 209 pk)
•1.9 TDI quattro (96 kw / 131 pk)
•1.8 5V T S3 Ambition (165 kw / 224 pk)
Seat Altea ('04-'15)
•1.6 (75 kw / 102 pk)
•2.0 FSI (110 kw / 150 pk)
•1.9 TDI (77 kw / 105 pk)
•2.0 TDI (103 kw / 140 pk)
•2.0 TDI (125 kw / 170 pk)
•2.0 TFSI (147 kw / 200 pk)
•1.4 (63 kw / 86 pk)
•1.8 TFSI (118 kw / 160 pk)
•1.4 TSI (92 kw / 125 pk)
•2.0 TSI (155 kw / 211 pk)
•1.6 TDI (77 kw / 105 pk)
•1.2 TSI (77 kw / 105 pk)
Seat Leon ('00-'05)
•1.8-20V (92 kw / 125 pk)
•1.8-20VT (132 kw / 179 pk)
•1.9 TDI (81 kw / 110 pk)
•2.8 V6 (150 kw / 204 pk)
•1.8-20VT Sport 4 (132 kw / 179 pk)
•1.8-20V Cupra R (154 kw / 209 pk)
Skoda Octavia ('97-'04)
•1.6 (55 kw / 75 pk)
•1.8 (92 kw / 125 pk)
•1.8 T (110 kw / 150 pk)
•1.4 (55 kw / 75 pk)
MegaRookie
Post by MegaRookie » Mon Jul 17, 2017 2:06 pm
Jep, thats me :D Glad to help!
Br Mark
Ps. Please say your brothers in law and your sister hi from me, its been a long time since we met!
andy198712
Re: T4 1971cc - Draw Through Turbo - VW Splitscreen
Post by andy198712 » Tue Jul 18, 2017 4:03 pm
can you mig that or are they ally and need tig?
Post by Piledriver » Tue Jul 18, 2017 5:53 pm
You just need a file. no need to fill the hole, the starters center in the transmission hole, not the bolts. Works fine.
Udo Airbus
Post by Udo Airbus » Wed Jul 19, 2017 1:36 am
Yes PileDriver , that was my idea too.. just for testing.. later make it reliable.
Udo Airbus
Br Mark
Will do when they are back from Italie!
Lukas49
Post by Lukas49 » Wed Jul 19, 2017 3:03 am
Udo, what jets do you use in carb? size?
Udo Airbus
Post by Udo Airbus » Wed Jul 19, 2017 3:30 am
Good question, now 135 fuel, air 160 .. venturi 36.. I think to small, we will see I will use my Wideband..
Will start small, i have some tools to make them bigger..
rubenski
Post by rubenski » Wed Jul 19, 2017 4:22 am
Boost referenced reguator?
Udo Airbus
Post by Udo Airbus » Wed Jul 19, 2017 4:39 am
that will be not needed for this engine at the moment.. those tweaks can always added later.
If it runs and drive... I will continue in saving money for EFI :)
GARRICK.CLARK
Post by GARRICK.CLARK » Wed Jul 19, 2017 1:01 pm
I bought mine from Auto Electric supplies in UK .
They have high torque starters for bug and type 2 vans.
Made by WOSP Performance. £200
Post by Piledriver » Wed Jul 19, 2017 1:54 pm
You can actually MIG aluminum with straight argon or helium (or various %blends of the two, the more helium, the thicker you can go for a given welder, hotter arc.)
This works best with a spoolgun, and usually provides serviceable welds for bulk fill anyway.
If you don't have a spoolgun, your MIG must be able to use the small ~100mm spools and ideally have a new teflon liner, and keep the cable as straight as possible.
Ideally your welder will have adjustable burnback, set to minimum, as the al wants to become one with the tip every time you shut off. Otherwise just try to make sure you have ~3/8" wire projection every time you let off.
MegaRookie
Post by MegaRookie » Thu Jul 20, 2017 8:12 am
@Udo, great! :D
For welding I used tig, with straight argon. Need good cleaning/grinding before welding.
