Page 3 of 4
Re: Turbo Buggy
Posted: Tue May 16, 2017 12:57 am
by mads b (dk)
time will tell if the turbo works or not..... I got if for free
the pipes are 36mm inside and 42.4 outside.....
Tapatalk
Re: Turbo Buggy
Posted: Tue May 16, 2017 1:49 am
by rubenski
Omg thats some heavy iron
Re: Turbo Buggy
Posted: Tue May 16, 2017 4:08 am
by mads b (dk)
stainless steel.... but yes it's heavy but I hope it will last long and without cracks
Tapatalk
Re: Turbo Buggy
Posted: Tue May 16, 2017 10:42 pm
by mads b (dk)
I have tried to messure the turbine wheel trim..... it's 47mm inducer and 43mm exducer..... so its not that big
after a lot of searching I found that it's a garrett GTB2056LV
[IMG]
//uploads.tapatalk-cdn.com/201705 ... 954933.jpg[/IMG]
Tapatalk
Re: Turbo Buggy
Posted: Thu May 18, 2017 12:48 am
by BlobDK
Hello Mads
Interesting project, I have tried that as well. I takes quite a long time to finish all the small parts:)
You can see my old engine here:
http://buggyforum.dk/viewtopic.php?f=9&t=1056&start=10
Where in Denmark are you located?
Re: Turbo Buggy
Posted: Fri May 19, 2017 10:29 pm
by mads b (dk)
Re: Turbo Buggy
Posted: Sat May 20, 2017 10:18 pm
by mads b (dk)
I have a old tread on the Danish site buggyforum as well
http://buggyforum.dk/viewtopic.php?f=9&t=1846
Tapatalk
Re: Turbo Buggy
Posted: Mon Jun 12, 2017 3:45 am
by mads b (dk)
Test Fitting [IMG]
//uploads.tapatalk-cdn.com/201706 ... 4949df.jpg[/IMG]
Sendt fra min SM-G935F med Tapatalk
Re: Turbo Buggy
Posted: Mon Jun 12, 2017 5:41 am
by BlobDK
I look forward to see it. It is more fun to see the projects that are special.
Re: Turbo Buggy
Posted: Mon Jun 12, 2017 4:39 pm
by petew
mads b (dk) wrote: ↑Mon Jun 12, 2017 3:45 am
Test Fitting
Are you sure you want to mount the turbo so close to the fibreglass body? Even with a turbo blanket on it?
Re: Turbo Buggy
Posted: Wed Jun 14, 2017 8:58 am
by mads b (dk)
Most fiberglass near the turbo is cut away and replaced by a stainless steel shield.... I'm considering to cut the fiberglass corner near the turbo downpipe[IMG]
//uploads.tapatalk-cdn.com/201706 ... 046dc6.jpg[/IMG]
[IMG]
//uploads.tapatalk-cdn.com/201706 ... 922a98.jpg[/IMG]
Re: Turbo Buggy
Posted: Wed Jun 14, 2017 3:09 pm
by petew
Ok, wow. There's a lot more space there than I thought.
With regard to covers. Aluminium will do a better job at moving the heat away from it.
Re: Turbo Buggy
Posted: Sat Jun 17, 2017 8:13 am
by mads b (dk)
First test run without turbo actuator, fully open vnt.... nearly no boost..... I hope it helps with the vnt closed
[IMG]
//uploads.tapatalk-cdn.com/201706 ... ce46ae.jpg[/IMG][IMG]
//uploads.tapatalk-cdn.com/201706 ... 1401be.jpg[/IMG]
Re: Turbo Buggy
Posted: Sat Jun 17, 2017 10:24 am
by mads b (dk)
Second test run permanent closed vnt..... 1bar boost@4400rpm running pig rich lambda 0.65....
0.2bar@3000rpm
Re: Turbo Buggy
Posted: Mon Jul 03, 2017 10:24 pm
by mads b (dk)
The buggy is nearly 100% up and running.... regarding turbo size it's making 0.5bar @ 2500 rpm
[IMG]
//uploads.tapatalk-cdn.com/201707 ... b86900.jpg[/IMG]
