Turbo Buggy
Moderator: seabeebuggy
mads b (dk)
Re: Turbo Buggy
Post by mads b (dk) » Tue May 16, 2017 2:57 am
time will tell if the turbo works or not..... I got if for free
the pipes are 36mm inside and 42.4 outside.....
Tapatalk
rubenski
Re: Turbo Buggy
Post by rubenski » Tue May 16, 2017 3:49 am
Omg thats some heavy iron
mads b (dk)
Re: Turbo Buggy
Post by mads b (dk) » Tue May 16, 2017 6:08 am
stainless steel.... but yes it's heavy but I hope it will last long and without cracks
Tapatalk
mads b (dk)
Re: Turbo Buggy
Post by mads b (dk) » Wed May 17, 2017 12:42 am
I have tried to messure the turbine wheel trim..... it's 47mm inducer and 43mm exducer..... so its not that big
after a lot of searching I found that it's a garrett GTB2056LV
[IMG]//uploads.tapatalk-cdn.com/201705 ... 954933.jpg[/IMG]
Tapatalk
BlobDK
Re: Turbo Buggy
Post by BlobDK » Thu May 18, 2017 2:48 am
Hello Mads
Interesting project, I have tried that as well. I takes quite a long time to finish all the small parts:)
You can see my old engine here: http://buggyforum.dk/viewtopic.php?f=9&t=1056&start=10
Where in Denmark are you located?
mads b (dk)
Re: Turbo Buggy
Post by mads b (dk) » Sat May 20, 2017 12:29 am
BlobDK wrote:Hello Mads
Fredericia
Tapatalk
mads b (dk)
Re: Turbo Buggy
Post by mads b (dk) » Sun May 21, 2017 12:18 am
I have a old tread on the Danish site buggyforum as well
http://buggyforum.dk/viewtopic.php?f=9&t=1846
Tapatalk
mads b (dk)
Re: Turbo Buggy
Post by mads b (dk) » Mon Jun 12, 2017 5:45 am
Test Fitting [IMG]//uploads.tapatalk-cdn.com/201706 ... 4949df.jpg[/IMG]
Sendt fra min SM-G935F med Tapatalk
BlobDK
Re: Turbo Buggy
Post by BlobDK » Mon Jun 12, 2017 7:41 am
I look forward to see it. It is more fun to see the projects that are special.πŸ‘πŸ‘
petew
Re: Turbo Buggy
Post by petew » Mon Jun 12, 2017 6:39 pm
mads b (dk) wrote: ↑
Test Fitting
Are you sure you want to mount the turbo so close to the fibreglass body? Even with a turbo blanket on it?
mads b (dk)
Re: Turbo Buggy
Post by mads b (dk) » Wed Jun 14, 2017 10:58 am
Most fiberglass near the turbo is cut away and replaced by a stainless steel shield.... I'm considering to cut the fiberglass corner near the turbo downpipe[IMG]//uploads.tapatalk-cdn.com/201706 ... 046dc6.jpg[/IMG]
[IMG]//uploads.tapatalk-cdn.com/201706 ... 922a98.jpg[/IMG]
petew
Re: Turbo Buggy
Post by petew » Wed Jun 14, 2017 5:09 pm
Ok, wow. There's a lot more space there than I thought.
With regard to covers. Aluminium will do a better job at moving the heat away from it.
mads b (dk)
Re: Turbo Buggy
Post by mads b (dk) » Sat Jun 17, 2017 10:13 am
First test run without turbo actuator, fully open vnt.... nearly no boost..... I hope it helps with the vnt closed [IMG]//uploads.tapatalk-cdn.com/201706 ... ce46ae.jpg[/IMG][IMG]//uploads.tapatalk-cdn.com/201706 ... 1401be.jpg[/IMG]
mads b (dk)
Re: Turbo Buggy
Post by mads b (dk) » Sat Jun 17, 2017 12:24 pm
Second test run permanent closed vnt..... 1bar boost@4400rpm running pig rich lambda 0.65....
0.2bar@3000rpm
mads b (dk)
Re: Turbo Buggy
Post by mads b (dk) » Tue Jul 04, 2017 12:24 am
The buggy is nearly 100% up and running.... regarding turbo size it's making 0.5bar @ 2500 rpm [IMG]//uploads.tapatalk-cdn.com/201707 ... b86900.jpg[/IMG]
