Yes, I'm building..., **EDIT** Bought a 2165cc :) Official 10sec car!! Now project 9sec...
Moderator: seabeebuggy
bug66
Re: Yes, I'm building..., **EDIT** Bought a 2165cc :)
Post by bug66 » Sat Feb 13, 2016 9:13 pm
Something has happened :D
I've done up most of the engine, still waiting for some good nuts for the rockers.
I need to re-TIG the piping between the top hats, to support installation of a IC.
Think I'll just move the blowoff pipe to the left, and angle the "T" down to the turbo.
I'll go with a cheap IC from Siliconeintakes.com.
Also building a new cage, mounting a new gearbox. Redoing seat mounts, fuel system, watersystem, EFI etc etc etc. :D
2165cc T3/T4 turbo, DTA S60 on E85.
Boost was created only to make people smile, and make power! 8)
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
bug66
Post by bug66 » Sun Feb 28, 2016 7:04 pm
And engine is in the car. Need to find a clean routing for waterlines, and above right shelf should do the trick. Water lines will run down the left side of the car.
Next up is to cut the middle piping, and weld it again, so that it lines up with a IC. Then make a watertank. A lot of small things left :)
bug66
Post by bug66 » Mon Apr 18, 2016 11:17 pm
Progress!
Clutch pedal:
Clutch management:
madmike
Post by madmike » Tue Apr 19, 2016 6:21 am
Nice CM :wink:
bug66
Post by bug66 » Tue Apr 19, 2016 7:58 am
madmike wrote:Nice CM :wink:
Thanks! Should do the trick. Stage 4 and thick BM disc, so need to slip some :shock:
madmike
Post by madmike » Wed Apr 20, 2016 7:35 am
wow,,,, stage 4 :shock: ,,, really necessary?? :roll:
Post by Chip Birks » Wed Apr 20, 2016 8:22 am
I think I felt my stage 3 slip a little the last time mine was on the track...heavy cars with lots of power can use a stout clutch, especially with clutch management.
bug66
Post by bug66 » Thu Apr 21, 2016 3:23 am
Engine was dynoed at 343 hp and around 360 ft. lbs at the wheels. "Full" weight steel 67 with cage etc etc.
So yeah. Stage 4 and BM is maybe overkill, but I'll rather slip the clutch via the clutch management, than slipping from to little clutch... :)
Kalle
Post by Kalle » Sat Apr 23, 2016 2:54 am
Hi guys,
Necessary or not. It is at least good to know that you have enough clutch. We use the CM to create enough slip to bring the 60ft down, save the gearbox and keep the front wheel at the ground. And it also helps to have a strong clutch for when you take the car to the dyno.
Keep on with the good work mister!
-K-
panel
Post by panel » Sat Apr 23, 2016 6:30 pm
bug66 and Kalle......can you give me the low down on how bug66's CM works? Like what that solenoid does and the proportioning valve is on top of the tunnel. Or what ever it is and why it's better than just the regular type/style etc ?
Subaru JDM EJ20 Turbo bus
Clonebug
Post by Clonebug » Sat Apr 23, 2016 6:56 pm
The solenoid is a pass through when off.
When on it diverts the fluid through the valve which is manually adjustable to control the flow for however fast you want the clutch to engage.
I'm sure It takes a few runs to adjust it correctly and also probably needs tweaking depending on track conditions and other parameters.
Post by Chip Birks » Sat Apr 23, 2016 9:10 pm
Typically you'll launch the car with the solenoid active, usually connected to a first gear switch of some sort, this just makes the clutch engage nice and slow on launch no matter how fast you release the pedal. Once the car is in 2nd, the clutch operates like normal.
bug66
Post by bug66 » Sun Apr 24, 2016 4:16 pm
panel wrote:bug66 and Kalle......can you give me the low down on how bug66's CM works? Like what that solenoid does and the proportioning valve is on top of the tunnel. Or what ever it is and why it's better than just the regular type/style etc ?
Chip and Clonebug are right.
I'll have a micro switch mounted so the solenoid only gets power when in 1st gear.
When I depress the clutch the fluid is routed outside the solenoid, and the valve is open flow in one direction. When I let the clutch pedal go, the fluid pressure wants to go back in the master cylinder, and is routed through the valve forward in the car. In that direction is the adjustment, and the clutchpedal will let the clutch slip the wanted amount.
Saves axles, 1st gear, no major wheel stands and no broken (hopefully) ring/pinion.
As I took the car for it's maiden voyage with the turbo engine today, it deserved a wash :)
panel
Post by panel » Sun Apr 24, 2016 7:53 pm
So you have one of these also ?
bug66
Post by bug66 » Mon Apr 25, 2016 1:33 am
panel wrote:So you have one of these also ?
If you mean the clutch slave cylinder, then yes.
