NEW plan - 1600 TURBO + oval + downunder
Moderator: seabeebuggy
66brm
Re: NEW plan - 1600 TURBO + oval + downunder
Post by 66brm » Sat Oct 14, 2017 12:28 am
Are the commondore injectors high z too? I'm in the market for a set too, perhaps go halves in a set for v8😀
Clonebug
Post by Clonebug » Sat Oct 14, 2017 11:12 am
Make sure you get them from a blown engine as most N/A V8's will probably not have big enough injectors for high boost VW engines.
Of course it will all depend on what boost level you want to go to.
If I were you I would try to find a minimum of 32 lb/hr. injectors which will get you to a little over 200 hp at 80%.
If you use 32# injector you limit yourself to that engine and since boost is addicting you will always want more even if you have to build a bigger engine.
There used to be a page on the internet that listed almost every injector by part number along with size and low/hi Z.
I haven't needed it in a long time but if I come across it I'll post it here.
I did a little searching.....
here is a calculator for injector sizing.
http://www.rceng.com/technical.aspx
Ah Ha!!!
I found it!!!
It was buried in my large stash of bookmarks.......;)
http://users.erols.com/srweiss/tableifc.htm
petew
Post by petew » Sat Oct 14, 2017 8:48 pm
Cool, I found them in the page. Bosch 0280155868.
363 cc/min as compared to the 208cc/min I have at the mo.
Post by Piledriver » Sat Oct 14, 2017 10:21 pm
One weird thing though, the Wide Band dropped out on every run. I don't know why, coz it ran fine on the way there and home. Weirdness.
Perhaps overheating the sensor?
They make sensor extensions and heat sinks for that.
Clonebug
Post by Clonebug » Sat Oct 14, 2017 10:32 pm
That will get you somewhere in the area of 220-250 hp.
Crank the boost!!!!
petew
Post by petew » Sat Oct 14, 2017 10:56 pm
I've looked them up on ebay...
https://www.ebay.com.au/sch/i.html?_fro ... s&_sacat=0
I can find 2 sorts. Brand new for approx $130/set or refurbed for around $200 a set. Thoughts?
Clonebug
Post by Clonebug » Sat Oct 14, 2017 11:33 pm
Here you go,
Sold each so you only need to get 4 instead of six.
$21.00 each plus shipping isn't too bad for brand new.
https://www.ebay.com.au/itm/Fuel-Inject ... SwXetZS1rC
petew
Post by petew » Tue Oct 17, 2017 3:24 pm
I'd be right in assuming new injectors means a completely new tune. Ie. starting from scratch? Correct?
Post by Chip Birks » Tue Oct 17, 2017 3:47 pm
Not quite. I think this is where the whole required fuel thing is nice. I think all you'll have to do is change the required fuel settings and it should rescale things to work. Piledriver or Mario or some other expert correct me if I'm wrong here.
Post by Piledriver » Thu Oct 19, 2017 12:28 pm
Chip is right, reqfuel rescale will mostly take care of an injector change.
...although a "full retune" is not something difficult or to be feared if you have your ignition already set and lambda delay table set reasonably.
With a little practice it literally only takes a few minutes to get to a reasonable ve table (NA, at least).
Note that it will never be perfect, as there is chaos in combustion itself.
petew
Post by petew » Thu Oct 19, 2017 4:07 pm
Cool, that's nice that I won't need to totally retune it.
My chaos is so awesome I don't need perfection. :lol:
In other news, I got mucking around (procrastinating) in the shed last night and came up with this horror story...
So I'll soon be ready for ratio rocker as well. :)
Clonebug
Post by Clonebug » Thu Oct 19, 2017 4:18 pm
i don't remember what cam or lift you have in that engine but you have soooo much more hp potential left in that engine you shouldn't have to even mess with ratio rockers.
Setting geometry and getting pushrods cut is such a PITA I don't think the gain would be worth it.
Crank the boost!!!!!
Just 3 more lbs. will make a bigger difference than any rocker change.........that would gain you almost 20% more power and all you have to do is open your laptop........ :shock: 8) :wink:
petew
Post by petew » Thu Oct 19, 2017 4:43 pm
Yeah, it's all the little bits and pieces that help. I've got a TCS10 cam (good for 1.25s) and a set of AA 1.25 rockers/manton chro-mo pushrods calling to me from the garage. I've also got my bleed valve on the bench. So when I can spring for those new injectors and cut me some pushrods, should be sweet. Hopefully that will lead to slightly earlier spool too.
petew
Post by petew » Fri Oct 27, 2017 6:29 am
Well, I think it's official. No.2 WB sensor and I are on the rocks. I tried extra hard to look after this one, but it's getting harder and harder to communicate. I get to keep the car though, so it should work out ok. We're keeping the lawyers out of it. ;)
I'm beginning to think it's vibration related. I was talking to a guy last weekend at the event and he was telling me they don't like vibration as well as too much heat. It's too far from the turbo to be getting a lot of heat. I reckon I need to look at the exhaust mounts and the cable too.
rubenski
Post by rubenski » Fri Oct 27, 2017 7:03 am
And check the wires inside the heatshrink.
I had it one time that the wires melted trough but the heatshrink sleeve was little melted.
One clamp came loose and touched the exhaust
