NEW plan - 1600 TURBO + oval + downunder
Moderator: seabeebuggy
Clonebug
Re: NEW plan - 1600 TURBO + oval + downunder
Post by Clonebug » Sun Oct 08, 2017 11:04 am
He doesn't have afr target on the graph at this time.
AFR target is only active during auto tune or if you have EGO activated. Then the ECU will try to follow the AFR target.
Post by Chip Birks » Sun Oct 08, 2017 1:36 pm
panel wrote:
Sun Oct 08, 2017 10:40 am
How close should the AFR (white line) and the Target AFR (yellow line) be in the graph/log ?
I like to set my graphs up so that my min/max are scaled the same for similar data streams. All of my afr related settings have a max of 20 and a minimum of 9. My egt all have a 0 min, and 1800° max, head temp shows 0-500°. You get the idea. Makes it so the traces will overlay with each other in a qay thay makes sense.
panel
Post by panel » Mon Oct 09, 2017 10:11 pm
I was curious re this graph :)
Subaru JDM EJ20 Turbo bus
petew
Post by petew » Mon Oct 09, 2017 10:23 pm
Yeah, that's before AFR target was working properly.
petew
Post by petew » Tue Oct 10, 2017 3:17 pm
Clonebug wrote:
Sun Oct 08, 2017 12:49 am
Your injectors are completely maxed out or you are running way too rich for the load......
I have seen 103% with my 32# injectors and I wasn't near the boost I am now.
That was at a peak rpm of 5800 at the rev limiter.
If you are running injectors 24# or less you are too small and need to limit your boost or get your afr's in check before you go to much farther.
I am running vacuum/boost to my regulator....it is a stock German FI bug regulator.
CB, my inj are 208cc/min. I don't know how that works in # settings. They're also low Z from memory.
Can you suggest something that's likely to be cheap and local to upgrade them?
Clonebug
Post by Clonebug » Tue Oct 10, 2017 7:51 pm
Yours are 19.8 lbs. per hr.
Good for about 39.6 hp each at 100% DC. So about 126 hp at 80% DC with all four.
Here is a calculator for ya.
http://www.rbracing-rsr.com/fuelinjectors.htm
If you have wrecking yards around, you could look for a mid 90's 940 turbo Volvo. They have 32# injectors which would get you to somewhere around 230 hp at 100% DC.
I know for a fact they are also low Z injectors because that is what I was running until this past winter.
I now have 45# injectors good for 360 hp at 100 DC.
petew
Post by petew » Tue Oct 10, 2017 10:17 pm
I just looked up the model #. It's Bosch # 0280150804. They want $280 a piece for new ones. OUCH! :(
I assume buying Chinese injectors is a very bad idea. Might have to ask a local guru... Hmm.
Clonebug
Post by Clonebug » Tue Oct 10, 2017 11:15 pm
Wow!!!
I got mine with a Fuel pump, Filter, injectors, TB, Idle air valve and the regulator for $20.00 American!!!
You can't find used ones anywhere???
petew
Post by petew » Tue Oct 10, 2017 11:44 pm
Ok, I'll have to keep my eye out. We did get 940 turbos over here but not many of them. I think I might try and chase up a JDM option. Cheap and plentiful over here.
66brm
Post by 66brm » Wed Oct 11, 2017 12:37 am
Pete, what manifolds and rails are you running, I may have a set never used apart from mock up from cbperf
petew
Post by petew » Thu Oct 12, 2017 3:16 pm
I'm using CB EFI manifold ends and fuel rails.
66brm
Post by 66brm » Thu Oct 12, 2017 9:20 pm
Cool will check what I've got
66brm
Post by 66brm » Fri Oct 13, 2017 9:10 am
26.65lb/hr low z set of four. Just need a new set of o rings?
petew
Post by petew » Fri Oct 13, 2017 3:26 pm
Cheers, mate. I've found a solution actually. Jason Smith (MS downunder group on FB) talked me through it. Commodore blown V6 are pretty well double what I have and a straight fit.
...and I realized I have high Z injectors. I'm such a duffer sometimes. :)
petew
Post by petew » Fri Oct 13, 2017 9:21 pm
A couple things have happened in the last few days. First up, I joined this club so that in a years time I can put the car on club rego and save myself nearly $1000 a year...
http://www.sydneyantiquemachineryclub.c ... rship.html
A good mate has a few hotrods registered with the club. Costs $50 a year for club rego. You can only drive it 60 days a year, but that's still once a week, so I should be fine.
This morning I went down to a "Men and Machines" show at Cobbity just south of Sydney. My car club was asked to come and put on a motorkhana demo, so got to have my first go at a motorkhana on the dirt. The paddock was pretty flat and safe and we only did a slalom up and back. We tried to make it looking more interesting with as much sideways action as possible. Lots of people were interested in car.
After us there were dirt bikes. It was pretty dusty when they came on so I went for a walk. This was the car I think I liked best. Simple, understated XR Falcon... werl except for the hoodscoop.
When I got back to car the, the monster trucks and offroad buggies had been tearing around the paddock. I was park right next door to it. Apparently the buggies had kicked up so much dust, the whole crowd just walked away.
I knew there was a reason I hadn't washed the car. :lol:
I did feel slightly sorry for the owners of the 200 or so other cars and harleys all shined within and inch of their lives. Not. :twisted: I hate harleys and I hate washing cars.
Car drove well there and back. Lots of fun 50mph country roads and a few pickup drivers who thought they'd roar past me and were surprised when I matched them. The motorkhana demos were good too. I haven't raced this car in a dirt motorkhana yet and I got more goes in 15minutes than I usually would in a whole morning I reckon. It went pretty well, considering I did nothing to tyre pressures or the like, and we didn't have quite enough space. Like last time, I found being more aggressive seems to work well. The club photographer was there, hopefully I'll grab some of his pics. One weird thing though, the Wide Band dropped out on every run. I don't know why, coz it ran fine on the way there and home. Weirdness.
