And having a couple rapid prototypes made to check fitment
What do you guys think?
The type modeled wouldn't need cast. They could be machined from solid FWIW.Piledriver wrote:you could use a common casting.
I like the looks of that as well. Installation looks easy too. I've had to tighten my self made brackets (one of my CB's broke so I made my own) and getting an allen wrench on both of the bolts is not an easy job.Turbo_Manx_Maniac wrote:I like the method Devastator uses to fasten the rail down, I was always a bit concerned with the CB stuff that the flimsy L bracket would give way and I'd spray fuel all over the place.
Turbo_Manx_Maniac wrote:I was always a bit concerned with the CB stuff that the flimsy L bracket would give way and I'd spray fuel all over the place.
These were the driving ideas behind my design. I don't know how likely the fuel rails are to come off during "normal" driving, but I knew that I never drive my sandrail gently. There is a small problem with my clamping method however. With the fuel rail in place, there is very little room for the injector wire clip. I have designed the cast version of the "L" shaped fuel rails and the "low profile" version to reduce this problem, but will not be able to evaluate their success until I cast a set and check the fit.56speedster wrote:I've had to tighten my self made brackets (one of my CB's broke so I made my own) and getting an allen wrench on both of the bolts is not an easy job.
I'm glad you like those!56speedster wrote:How much for a set just like those Devastator?
