Starting to get my engine parts and have some questions
- frankysfree
Re: Starting to get my engine parts and have some questions
Sent the case off to Rimco to have the piston oilers installed.
Next on the list is the heads and still got to order the connecting rods.
Got my new Wiseco Pistons today. Man, these things are sweet!!
- frankysfree
Case arrived at Rimco today. They are doing the piston oilers and im also having them do the mod for better oiling.
Ordering some new parts next week. Pretty soon im going to have to start a build thread
Make sure you use a good oil cooler and fan set up when using oil squirters to cool the pistons. Oil temps get raised 30-40 deg. No not just a 72pass, maybe 2 I would at least sack them up to save room. That's what I did on my street car.
Shag Leone, SL-1 Racing
325WHP and 290TQ @17# on 91oct
383WHP and 324TQ @23psi on 50/50 mix
What's next?
Need a turbo or parts!
[email protected]
Facebook at SL 1 racing
What's next?
[email protected]
- frankysfree
Good advice. I was definately planning on running an oil cooler and fan.
- frankysfree
I may be welding some water jackets in the heads as well to keep temps under control.
Get a dual setrab fanpack from aircooled.net that will handle all the heat you can throw at it.
Steve
My Baja Build
My Baja Build
- frankysfree
Looks like a good cooler setup. Where do you guys mount those at on a bug?Steve Arndt wrote:Get a dual setrab fanpack from aircooled.net that will handle all the heat you can throw at it.
The single fan pack can be mounted to the side and above the trans. Two singles may fit easier than the dual model.
Here are some google images;
https://www.google.com/search?hl=en&cli ... 0gGxlYS-DQ
Steve
My Baja Build
My Baja Build
- frankysfree
Looks like it might be hard to fit the dual model, i may just go with two singles.
- frankysfree
Should be getting my case back from Rimco today or tomorrow with the oil squirters and the HVX extra oil port machined in the case. Getting excited except im bleeding money on this thing and havent even got a complete short block together yet, let alone a long block, FI, turbo, etc.
I see this is an old post but did you take any pics of the oil squirters and case oiling mods by Rimco? I am building a engine for a 1600 class and was thinking of case mods. How about feedback on engine temps?
If you feel you are picking up speed you may be going downhill.
