1600cc Low Budget Turbo build
E_bug
Re: 1600cc Low Budget Turbo build
Post by E_bug »
Thanks for the replies guys.
I wasnt measuring at the thread...
:wink:
All buttoned up and torqued finally! :!:
My welding sucks .
E_bug
Post by E_bug »
Its MS time :)
I have ms2 v3 configured to run edis.
My engine is 1641 with a small kkk15 turbo.
Can i please get a base startup map?
I will also have to work around my sp head situation :)
My welding sucks .
Clonebug
Post by Clonebug »
Each engine is it's own setup.
You really can't use someones map since all the variables would not be set to your configuration.
You need to set it up for your ignition, injector size, engine size and a host of other things.
For example...I have 32# injectors and direct fire the Edis Coil. That is not compatible with your EDIS module and lets say your possible 19# injectors along with whatever trigger wheel you are using.
E_bug
Post by E_bug »
So i should go step by step through the instructions on megamanuall .
I wasnt going to drive it with a donor map, just to get going. Its on a stand coupled with a trans to set up everything.
C
My welding sucks .
E_bug
Post by E_bug »
So after a loooong time
Take a look at my progress.
BTW do you think my pulley idea will work for crank trigger?
My welding sucks .
madmike
Post by madmike »
Looks like a Metal eating Beaver got a hold of it :lol:
