align bored case, bronze bushings with slots for full time oil to the heads,oil mod for more oil to 1/2 side cut for 92's
bearings cut on inside for full time oil,xr 296 cam on 112lc,cb light weight lifters,cb push rods,cb 30mm oil pump,rc 550 injectors,turned down mahle 94's with 5cc dish, cylinders honed to 005 clearance,full set of total seal rings, 12 pound flywheel,daiken disk,kennedy stg 1
brothers vw crank,h beams with arp bolts,cb straight cut cam gear,36 tooth wheel on empi sand seal pulley
cb header,airesearch t3/t04b turbo,38mm tial wastegate,and assorted pipe
edelbrock/bbc throttle body,intercooler,turbonetics blow off valve,my 2 inch home made ss intake pipe
another one of my old intake and my new intake/ends(still have to cut down pipes)
cb high flow end castings with rc 550 injectors
brothers vw 42x37 heads with cb 650 springs, turbo prep
3.88,378,206,126,089 all course splined no keys,super diff, all steel caged bearings,x2 hd side cover, empi crmo axles
