Nice looking Buggy there Maxray and good save on not admitting on being the driver....
I'm thinking due to what has been said around here that your choice of turbo is going to be too small.
I'm sure Mini will be around to set you or me straight soon.
What is the outlet size of the compressor?
Mine is 1 3/8 inch on the inside of my IHI RHB5 and it heats the air up pretty good by the time I get to 12-13 lbs.
If you find one with an outlet of 1 1/2 inches you should be pretty good unless you want 20 lbs. of boost.
Don't kid yourself.....you won't be happy with 5-8 lbs. after about a half a day.....
Ask me how I know.
You have your eye on some pricey hardware there which is really nice to have but it adds up in a hurry.
You could use a turbo that has a internal wastegate and make yourself a boost controller out of a 1/4 inch brass tee....
A cheap BOV is available from the Saab turbo...about $15.00 or so if you shop around. It's not the fancy billet kind but if you are starting out it works good.
Just remember... it gets really tight in the back due to not much space if you have a rear section that hangs down like a Real Manx or a buggy like mine.
I have no room under the body once the carb, Edis coil and module were placed there.
I'm not sure how high the intake is on that Mexican throttle body but you might have to do some creative plumbing to get the turbo feed under there.
If you need to read a boring build thread on my troubles you can go here.
http://www.shoptalkforums.com/viewtopic ... 3&t=127936
Like I said.... it gets full in a hurry so plan your layout well. At least you won't have to pull a carb to rejet every 10 minutes like I did...
Clonebug
