Page 47 of 70
Re: 250HP 1600dp
Posted: Fri Dec 29, 2017 10:33 am
by WickedWagens
I'm just starting mine. 66x85.5 I should have gone 64x87 but the crank was a trade so I can't complain. Turbocharged for land speed racing at the Bonneville salt flats.
Re: 250HP 1600dp
Posted: Fri Dec 29, 2017 11:03 am
by Clonebug
WickedWagens wrote: ↑Fri Dec 29, 2017 10:33 am
Oh come on Wicked.........no teasing!!!
What is your boost target, rpm, fuel supply, hp target and all that other good stuff we need to know?????
Re: 250HP 1600dp
Posted: Fri Dec 29, 2017 2:41 pm
by WickedWagens
Clonebug wrote: ↑Fri Dec 29, 2017 11:03 am
I'm hoping for around 20 lbs boost, 7000 rpm, and enough HP to go 150+ MPH. I don't know if I'm going to try a DHLA 40 or a 2 barrel holley blow through.
Re: 250HP 1600dp
Posted: Fri Dec 29, 2017 3:39 pm
by Clonebug
20 lbs boost and 7000 rpm with 92 ci. will get you 240 crank hp according to my favorite calculator.
You will need 26.4 lbs/min air or 327 CFM to accomplish that.
That is with the VE down to .89 which is corrected to match my engine output. YMMV
You'll need a good intercooler to keep your IAT's in check depending on how hot it is there...I used a default of 130 degree IAT's to get that flow.
I would think WI might be a good add on to keep your IAT's in check....just carry enough to stay on boost that long.
Re: 250HP 1600dp
Posted: Fri Dec 29, 2017 4:38 pm
by petew
Nice. Who made that crank up?
Re: 250HP 1600dp
Posted: Fri Dec 29, 2017 5:11 pm
by WickedWagens
It’s a DPR crank.
Off Topic
Great. 225-240hp should make my goals for the speeds I want.
Re: 250HP 1600dp
Posted: Sun Dec 31, 2017 6:40 am
by buguy
I don't know how much difference it would make but a 1600 is 97 ci not 92.
Re: 250HP 1600dp
Posted: Sun Dec 31, 2017 7:48 am
by Chip Birks
buguy wrote: ↑Sun Dec 31, 2017 6:40 am
66x85.5 isn't a 1600
Re: 250HP 1600dp
Posted: Sun Dec 31, 2017 8:20 am
by buguy
Oh! I just saw 1600 in the title.
Re: 250HP 1600dp
Posted: Sun Dec 31, 2017 9:53 am
by MarioVelotta
I want to change the title of this post and am looking for input.
Current Name:
250HP 1600dp
Proposed:
250HP+ from a Mouse Motor
250HP+ from 1500cc - 2000cc
Looking for other options and opinions before I make the change
2018 will be the year my Mouse gets put together!
Happy New Year
Re: 250HP 1600dp
Posted: Sun Dec 31, 2017 11:43 am
by WickedWagens
I would say keep it mouse motor. 1641cc limit or something. I started my own build, but I will add highlights in here.
Re: 250HP 1600dp
Posted: Sun Dec 31, 2017 12:08 pm
by Chip Birks
Mighty Mice!
Re: 250HP 1600dp
Posted: Sun Dec 31, 2017 12:49 pm
by buguy
I always think of anything under 1776 as a mouse! Find or sketch up some ideas and I will see about getting some stickers made!
Re: 250HP 1600dp
Posted: Sun Dec 31, 2017 5:13 pm
by Clonebug
Me me me!!!!
Under 1700 cc's please!!!!!
Re: 250HP 1600dp
Posted: Sun Dec 31, 2017 6:12 pm
by MarioVelotta
For me, a mouse is under 100ci. 1641 is really close but over. The 11,000 rpm 1776 motor from JPM is considered a Mouse by most.
