i think wally also will build such an tiny fun eingine
the engine facts:
1192cc
77mm polo g40 oversize pistons machined to 35,85mm compression hight 14,75cc chamber
64mm stock crank + lighter flywheel ballanced together with pulley and pressure plate
stock ballanced conrods with new bushings 470g
stock zylinders shortened
1300 DP heads with 34,5/33mm valves, ported, B-chamber and 21,2cc
1,3:1 rato rockers
outer springs with 104kg at 1" (from scat double springs)
merged changed
garrett gt 1752 turbo (changed a bit)
pop off
water intercooler
maybe waterinjection if needed
E85 fuel
injection AME or MS1Extra HR not set jet because AME is favorit but will get new mass flow sensor at the moment.
porsche cooling because it was here in the garage...haha
stock cam first. infact that a friend of mine has a simmilar engine with lower compression and pushes 1,6 bar aut of a k03 through a 34 pcib carb without any kind of intercooling ans revs over 6000RPM + an 2009 dynoed engine very simmilar to our hat peak at 6800rpm with stock cam and 1,25:1 rocker....we will see.
some pics:
this all goes next into my rusty 60 bug wich has at the moment my 36 supercharged engine into it.
the new home
if somebody has some improvements in theorie or some ideas to make more and more power out of it let me now.
our goal is 150hp plus.
wishes
chris
