Safari Turbo/Megasquirt Fuel Injection Project
Moderator: seabeebuggy
Clonebug
Re: Safari Turbo/Megasquirt Fuel Injection Project
Post by Clonebug » Mon Nov 06, 2017 10:58 pm
Getting ready for my test of airflow to the intercooler.
Except it's too cold out right now.......
Post by Ol'fogasaurus » Mon Nov 06, 2017 11:44 pm
Too cold out..phsaw! You work in worse that is out there right now :lol: It should be easier as you are having fun.
On you mockup, add so tells on the down side to see what his happening there. I don't think you want a vacuum sucking air that way blocking air flow so you need to check for it.
rubenski
Post by rubenski » Tue Nov 07, 2017 2:44 pm
Dont you think the cardboard will just blow open and the rectangular shape will turn round on the top?
GS guy
Post by GS guy » Tue Nov 07, 2017 4:27 pm
That's an interesting point - the shape or bends the box assumes at speed may be very telling!
Another thought - be sure to bring the tools and flip the box to rear-opening for a 2nd run. There's a chance it may get better air-flow through the core coming from the rear! Going by the various air-flow video's and pictures I've seen, there's a good possibility there will be "backwards flow" at the upper rear of the car at speed.
Jeff
Clonebug
Post by Clonebug » Tue Nov 07, 2017 10:37 pm
It's not meant to last very long.
I only made it to give me a pattern so I could see how it fit on the intercooler. I'll probably just drive really slow first to see how it handles the wind and if it holds I'll increase the speed a little at a time.
I'll keep a close eye on the IAT's to see if it cools better.
Post by Ol'fogasaurus » Tue Nov 07, 2017 11:08 pm
Another thing would make a wing shaped unit.
The open sides s/b closed and taped shut for testing, you want to control the air flow over and through you cover. Put cotton tells top, sides and rear then get moving with a GoPro or someone riding in another vehicle video tapinging the rear area you are working on. You have to know what is going all around which can affect any air flow from the rear of the body and the cover that can affect the engine itself.
Looking good!
Clonebug
Post by Clonebug » Wed Nov 08, 2017 12:09 am
Looking good!
The sides are not open.....everything is tight against the aluminum intercooler core and is sealed as well as it can get as if it were an aluminum scoop.
If it flexes...so be it......if it rips off that will mean it is catching lots of air and it will be worth going to the next level and bending some aluminum........
Also in the first pic you can see my little Mobius video camera mounted and pointed backwards for live recording while I drive..... :wink:
Post by Ol'fogasaurus » Wed Nov 08, 2017 11:52 am
The sides are not open.....everything is tight against the aluminum intercooler core and is sealed as well as it can get as if it were an aluminum scoop. I wasn't sure just what the black area was. I saw the flaps bolted in place but again, I just wasn't sure.
If it flexes...so be it......if it rips off that will mean it is catching lots of air and it will be worth going to the next level and bending some aluminum........ When I was still working, normally I would recommend having the flap tied directly to the rear piece as there could be a lot of wind loading/disturbance (as you inferred to) that way but again, it is your design and it really isn't my job anymore.
Also in the first pic you can see my little Mobius video camera mounted and pointed backwards for live recording while I drive..... So, that is what that little black ball thing is. I wondered but now I know. 8)
petew
Post by petew » Wed Nov 08, 2017 7:44 pm
Like button :)
Now, here's my guess... there'll me more hot air coming under the car than cold air going into the scoop. Now take a vid and prove me wrong. :lol:
Clonebug
Post by Clonebug » Wed Nov 08, 2017 7:59 pm
I tried tonight.........battery is deader than a doornail and now it's dark....... :roll: :x :cry:
Clonebug
Post by Clonebug » Sat Nov 11, 2017 4:17 pm
Mileage 89,405
I took the buggy out for test and the scoop did help a little but that is not accounting for the ambient temp change if the was one.
The low before the scoop was 117 degrees
Low with the scoop forward was 110 degrees.
Low with the scoop turned around was 107 degrees but my clutch slipped so bad in third and fourth I had to pedal the throttle through the run.
Highest boost was 22.3 lbs.
This test was in no way scientific and the scoop facing either way really isn't a fair test due to the boost levels not being exactly the same and also the clutch slippage.
With the clutch slipping I can't get a load on the engine to get the boost all the way up either.
Either way I'm happy with the addition of the intercooler since it does help and it only cost me some bends and a few silicone couplers.
I have some video facing the back and I will try to get it uploaded to Youtube later with a link here.
buguy
Post by buguy » Sat Nov 11, 2017 8:47 pm
I can't wait to see the video!
GS guy
Post by GS guy » Sat Nov 11, 2017 9:49 pm
Ditto! Could you tell which direction the air was trying to go through the IC? Top to bottom/bottom to top/front to back/etc?
Clonebug
Post by Clonebug » Sat Nov 11, 2017 11:10 pm
The yarn on the seat was blowing forward and it looked like the next layer down was blowing back.
When I had the shroud backwards the yarn on top was trying to go into the shroud.
Otherwise it was hard to tell but it seemed there was a good amount of turbulence.
I already knew that due to my hair always getting blown forward.
The video of the hardest launch for some reason quit when I hit third gear.
There is only one other one that was a hard pull which turned out pretty good. The rest were cruising around and waiting for cars to go by so I could give it a full boost test.
I don't like doing over 100 mph when driving toward traffic......it's a good way to get thrown in jail........ :oops: :shock: :cry:
Clonebug
Post by Clonebug » Sat Nov 11, 2017 11:26 pm
The video is up.....
https://youtu.be/gV9ELjDq5-4
