Safari Turbo/Megasquirt Fuel Injection Project
Moderator: seabeebuggy
66brm
Re: Safari Turbo/Megasquirt Fuel Injection Project
Post by 66brm » Sun Oct 22, 2017 10:11 pm
I would think that the fan may also help with heat soak in the core if it's left to run for a bit after a hard pull
petew
Post by petew » Sun Oct 22, 2017 11:13 pm
Clonebug wrote:
Sun Oct 22, 2017 9:56 pm
In the October air I see 135-147 plus degrees at 22-23 lbs. with the WI on.
The first pass through third gear it held it down to 83.7 degrees so that would be a 61 degree drop......
The third pass was at 117 degrees from say 145 degrees would be a 28 degree drop.
It really doesn't have a lot of airflow so maybe once I install a fan it will maintain the lower temps. that would be the cat's meow!!!
I could otherwise inject some of my water/alcohol onto it for some cooling help but I can already really feel the difference just the 30 degrees makes.
So, what you're saying is, you get a 50% drop in IATs if you can supply it with cool air. That's pretty awesome! I still say finding a way to get fresh air to it without a fan is a better idea. A scoop or a few well placed bits of vacuum cleaner hose would probably do it.
kangaboy
Post by kangaboy » Mon Oct 23, 2017 11:42 am
Was the motor fully warmed up? I'm curious if the heat soak you mentioned will make the boost temps go up a bit after you are at full cruising temp. Your temps are very intriguing, and really make me want to pull the trigger to get some kind of intercooler on my setup for some more boost...
'74 Standard- 1776T, MS3X3
'76 Westy- Stock 2.0L L-Jet
GS guy
Post by GS guy » Mon Oct 23, 2017 11:54 am
Is that without the WI? IC only? If so - that's freak'n awesome! That's a significant drop in temps (even if it's with the WI). A longer shake-down cruise will verify the effectiveness, ALA the clutch holds up!!! :shock:
Jeff
Clonebug
Post by Clonebug » Mon Oct 23, 2017 1:55 pm
GS,
That was with WI on too.
It's still quite noticeable on the performance side I feel.
It seemed a lot stronger in the middle range lower gears too.
GS guy
Post by GS guy » Mon Oct 23, 2017 2:29 pm
Sweet! Don't forget the yarn "wind tunnel" testing. Could be very enlightening.
Jeff
Clonebug
Post by Clonebug » Mon Oct 23, 2017 10:57 pm
The first pass was after a 5 minute warmup idle and then 2 mile drive before boosting it to watch the IAT's at cruise.
It would idle at about 95 degrees with a 65 Degree ambient air temp.
It would run at about 78 degrees at cruise if I remember correctly and hold there. the first run I checked the log was just a fairly easy push in first and second then hard boost in third which only lasted about 5-6 seconds. That was the reason it stayed low.
Third pass was more revealing in what it will do I think due to a hard pass in all the gears including fourth which put a long load on the turbo.
Clonebug
Post by Clonebug » Mon Oct 23, 2017 10:59 pm
Jeff
That is next on the list... :wink:
petew
Post by petew » Tue Oct 24, 2017 6:18 am
Some inspiration for you Art...
http://www.youtube.com/watch?v=zunAeYDh0PA
rubenski
Post by rubenski » Tue Oct 24, 2017 6:21 am
I shared it on facebook also, awesome launch!
petew
Post by petew » Tue Oct 24, 2017 3:29 pm
Yes, but VERY squirrelly after that! :shock:
Clonebug
Post by Clonebug » Tue Oct 24, 2017 8:12 pm
Why does it do a 10.90 second pass but only 97.28 mph???
Shouldn't it be at almost 130 mph???
It does launch hard!!!
Post by Piledriver » Tue Oct 24, 2017 9:00 pm
10.90 index, standing on the brakes at the finish line?
Clonebug
Post by Clonebug » Thu Nov 02, 2017 11:32 pm
Nothing big happening......weather has turned for the worse and it has been raining or too cold to drive the Buggy.
Pulled the intake off and got it painted....
The clocking bracket arrived so I also installed that.......just a little stainless bling..... :wink:
rubenski
Post by rubenski » Fri Nov 03, 2017 3:07 am
