Engine will be a 84x94 built in a CB alum case.
So far I have the case:
It's been to RIMCO and had the center main cut for a type 4 bearing, cut for a sand seal, and all the galleys tapped.
Parts I have so far:
SCAT 5.5 H beam rods with 3/8 ARP 2K bolts, Clevite 77 VW rod journal bearings, Mahle main bearings, and misc parts to put the crank assy together.
I have the crank & FW on order at DPR, it's 84 stroke, type 4 center main, VW rod journals, 12lb flywheel wedgemated.
That's where I am today.
Motor is primarily for off road use and a little street. Everyone in my group went turbo Subaru, I still like VW and am gonna show them a bit of german HP. Don't bother telling me to go water pumper, I'm stubborn as a bull.
I don't care about dyno numbers, I'm shooting for major low end torque and violent power on boost. Haven't picked a cam or head combo yet, still thinking about it. Compression will be 8.25:1 or therabouts. Would love to hear suggestions. One friend is pushing Tim's stage 2+, the 120 with 1.25's, I was thinking an 86B on 112LC and CB oval ports.
What I'm hung up on now is the induction system. I am using the CB FI end castings now, but don't like the sharp airflow transition into the heads, was thinking about some IDF type manifolds and a small plenum like Marty makes hooked to a single throttle body. Would appreciate comments on this too.
C-YA in the dirt
