Tools what to bring and what to have around the house.
bikesndbugs
Post by bikesndbugs » Thu Nov 02, 2017 3:24 pm
Trying to come up with a general list of what tools one should have for a baja bug. In order of most important.
Fabrication tools
Grinder
drill
Welder
Tube bender
Chop saw
(That seems like the bare minimum. For major fab some minor fab all you need is welder and grinder)
In car
Oil
fire extinguisher
Screwdriver
Needle nose plyers
Zip ties
elctrical tape
duct tape
Tire plugs
Tow strap
Socket/ wrenches
Bottle jack(at least)
Carb cleaner
Hammer
Axle nut wrench
A few wire ends male and female with crimpers
A bit of extra wire
Fuel line.
Dist cap and rotor
Spark plugs.
Anybody else have suggestions.
Travis
Re: Tools what to bring and what to have around the house.
Post by Ol'fogasaurus » Thu Nov 02, 2017 5:30 pm
A tow strap!
A bottle jack I am not sure about. It might be too short for off-road problems.
There are some parts I would also carry like:
A spare high tension lead (from the coil to the dist).
A spare cap and rotor.
Spark plugs.
Oil.
A survival kit in a can which includes a poncho, something to eat and water. Add to that a phone just in case.
A flash light or two.
A "joy roll".
Some things w/o getting too silly. :roll:
Ed ke6bnl
Post by Ed ke6bnl » Thu Nov 02, 2017 6:19 pm
I carry a fire extinguisher inside and outside the vehicle
I also carry a few sticks of arc welding rod for the time I may need two batteries and jumper cables to do a temp. weld.
Agua Dulce, So.California
1968 2.2L Ecotec Power Baha Bug, king coils, etc.
1950 F1 street rod
1949 F1 stock V8 flathead
1948 F6 350 chevy/rest stock
1953 chevy 3100 AD for 85 S10 frame
1998.5 Dodge 2500 4x4 Cummins, p etc.
bikesndbugs
Post by bikesndbugs » Thu Nov 02, 2017 6:21 pm
Ed ke6bnl wrote:I carry a fire extinguisher inside and outside the vehicle
Good one forgot that.
How about some tools that stay in the garage/ shop that would be necessary for a bug.
Brake line bender
Sent from my LG-H872 using Tapatalk
Travis
chuckput
Post by chuckput » Thu Nov 02, 2017 10:38 pm
If you are bending and welding tubes, you might need a tubing notcher. I also have two types of reciprocating saws (Sawzall) - one large, one small - that have come in handy. I also find my drill press to be very valuable. Hand drills are great, but for percision, you can't beat the drill press. I also love my "rattle gun" - lightweight impact driver.
To the survival kit I would add some sort of fire starting device (I'll let you choose).
But it seems like no matter how well equipped you are, when you really need that "right" tool, you won't have it.
bikesndbugs
Post by bikesndbugs » Thu Nov 02, 2017 10:50 pm
I notch tubes with the cutting wheel or chop saw.
Sawzaw is nice.
Travis
Post by bajaherbie » Sun Nov 05, 2017 8:39 am
TWO grinders, one with a thin cutting wheel and the other with a flap sander disc on it!
Post by Ol'fogasaurus » Sun Nov 05, 2017 8:47 am
To add to what Chuckput said, I would add a drill bit centering tool. You mark your spot, then put it on the press platen (over the hole in the platen or a sacrifical scrap, drop the locating tool down to center it at your marked location, clamp everything in place, replace the locating tool with a bit then have at it.
Two of the tools I use most are my blast cabinet and a grinder on a stand with a wire wheel at the other end of the motor (safety glasses!!!!). A good 60 gallon (minimum) compressor is also a must in my opinion.
He who must not be named!
chuckput
Post by chuckput » Sun Nov 05, 2017 2:29 pm
Your in car list should include tape - both electrical and "duck" tape.
