cnc slave adjustment for clutch
mlrailguy
Post by mlrailguy » Sat Sep 09, 2017 6:38 pm
Tried doing search here, but wasn't having much luck. I've got the CNC pedal setup in my buggy. The clutch seems hard to push and the clutch engages right off the floor. Maybe my legs are too short and I just can't push pedal far enough in? What kind of adjustments can I do here? The reservoir is a little low.?
dustymojave
Re: cnc slave adjustment for clutch
Post by dustymojave » Fri Sep 15, 2017 2:51 am
The slave cylinder has adjustments on both ends. Should be a wing nut at the throwout arm. Then another nut for adjustment at the opposite end where the slave cylinder anchors.
There should be a little play at the pedal, but then it should start moving the throwout arm. You might do a travel test by having a helper depress the pedal all the way, then putting a crescent wrench on the end of the throwout arm and trying to push the top of the arm forward more. If it goes much farther, then you need to adjust the nuts to make the slave cylinder effectively shorter.
It IS possible for those threaded shafts to screw out of the slave cylinder. They should be installed with red Loc-Tite. The threaded rods into the slave cylinder...Not the nuts on the rods.
Richard
Lake LA, Mojave Desert, SoCal
AKA: MojaveRacer208
Post by Ol'fogasaurus » Fri Sep 15, 2017 9:18 am
Notice the different threaded lengths in the two slave cylinders. I think this is what Dusty was talking about.
How much free-play do you have on the clutch arm before the throw-out bearing before the bearing comes into contact with the pressure plate/clutch cover; in my Haynes manual, for a bug, the table says 1/2' to 3/4" for free play at the clutch pedal.
mlrailguy
Post by mlrailguy » Fri Sep 15, 2017 11:59 am
The top end was already tightened as far as it would go, so I started taking up slack on other end. Feels better just idling in garage and shifting thru the gears. Will know better tomorrow once out hitting the dunes
mlrailguy
Post by mlrailguy » Fri Sep 15, 2017 12:01 pm
By the way Ol'fogasaurus , that is an awesome pic for reference. Thanks !
Post by Ol'fogasaurus » Fri Sep 15, 2017 1:13 pm
:wink: :)
