cnc slave adjustment for clutch
mlrailguy
Post by mlrailguy » Sat Sep 09, 2017 6:38 pm
Tried doing search here, but wasn't having much luck. I've got the CNC pedal setup in my buggy. The clutch seems hard to push and the clutch engages right off the floor. Maybe my legs are too short and I just can't push pedal far enough in? What kind of adjustments can I do here? The reservoir is a little low.?
Re: cnc slave adjustment for clutch
Post by Ol'fogasaurus » Sat Sep 09, 2017 7:18 pm
Is your slave cylinder hookup anything like this? If so there might be some adjustment at both ends of the slave cylinder's rods. Make sure the slave cylinder fully bled too. Also, the angle of the arm vs. the slave cylinder can make a difference.
cbeck
Post by cbeck » Sat Sep 09, 2017 8:18 pm
I went from a 5/8 master to a 3/4 mc, could not believe how much harder the pedal was to push. About to spend the cash for another 5/8. My cnc slave is threaded on both ends like lee's pics.
mlrailguy
Post by mlrailguy » Sat Sep 09, 2017 8:56 pm
Exactly what I have. I tried tightening the fixed end a bit. Haven't driven it yet, but it shifts into first now much easier. It still is engaging just off floor, but maybe that's a good thing? Should I tighten it up a bit more?
Post by Ol'fogasaurus » Sat Sep 09, 2017 10:20 pm
Do you have a long or short cross-shaft arm, the one the slave cylinder connects to. That also might make a difference.
Check the throw out bearing fork's connections to this cross shaft, they have been known to break loose.
