DesertGuy 2.0
Re: DesertGuy 2.0
Very impressive! Too much great work to take in all at one time. Wow!
- Getrdone
Re: DesertGuy 2.0
Looks like I may need to pick up the phone. Give it another day
- motorbreath53
Re: DesertGuy 2.0
THE most spectacular "DIY" build I have seen.... stalled when its time for fueling up and a trip around the block? What gives?
Do you want me to come drive it first? Cause I would... FOR YOU, of course. Just here to help....
Baja5 was right...
Re: DesertGuy 2.0
Have faith... work is still happening. Should have a few update pics soon.
- motorbreath53
Re: DesertGuy 2.0
PFFFFFTTTtttt..... I think i've proven time and again that I do not have patience... what makes you think now will be different?
Baja5 was right...
Re: DesertGuy 2.0
Waterlines, Power Steering, Brakes, Clutch and Fuel all plumbed up. Weddle Twin disc clutch goes in this weekend...
Had Lance from PVP Performance Vehicle Plumbing swing by and plumb the car... if you are looking for a mobile service to show up at your door with all equipment and supplies and plumb your car, Lance is the way to go.... https://www.facebook.com/PVPperformance
All Fire Sleeved up...
- CentralWAbaja
Re: DesertGuy 2.0
Put a peddle stop on for that Weddle!
Oh and everything looks killer there as always
- bajaherbie
Re: DesertGuy 2.0
is the grey(silver?) on the flex fuel lines an additional sleeve? and a rubber boots on the AN fitting?
Re: DesertGuy 2.0
The fuel hose is a black nylon double steel braided hose that has some fancy inner core to resist breakdown over time. The outer sleeve is called Firesleeve, it can withstand transient temperatures up to 2000 degrees and prolonged exposure up to 1000 degrees, if I remember right. The heatshrink is high temp, fuel resistant to keep the area between the hose and sleeve clean and sealed.bajaherbie wrote:is the grey(silver?) on the flex fuel lines an additional sleeve? and a rubber boots on the AN fitting?
The Firesleeve is a safety item: it can resist high temps, allows for another barrier between the hose and fuel and 'insulates' the fuel helping the fuel to not 'boil up' reducing possibility of vapor locking in higher temps. At least that is what those that know that stuff tell me right before they take my money.
- Devastator
Re: DesertGuy 2.0
That's mighty nice of them to tell you.DesertGuy wrote:At least that is what those that know that stuff tell me right before they take my money.
Devastator's Build Thread
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
Re: DesertGuy 2.0
The Mars rover wasn't built with this attention to detail! Nice to see it so close to being finished DG.
Re: DesertGuy 2.0
Buttoning the car up further, working on fuel area. Re-worked the vent tube to omit the dogleg in the tube... and, of course, a change in color to transparent copper.
