to sound deaden or not
how much ttrouble is it to put sound deadening material in the car before I put in the panels, and the rug, etc........
does it make a big difference?
have you guys done it?
how long does it take?
thanks
thanks
I used a paint called Quietcar. It is supposed to work as well or better than mats. It is light weight in comparison to mats, and much cheaper considering the area covered. About $60/gallon, but I still have some of one gallon left, and I did the entire inside of my Ghia with three coats. I think it helps quite a bit. It is defineately much quieter, but it is kind of hard to tell how much the paint did, as I also put in carpet and insulation, and a back seat, all of which was lacking before the sound deadening. I am still planning on painting areas in the trunk, and under the floor pans. Maybe even in the wheel wells if I get a chance. The website is www.quietcar.net.
hey,\
here are some threads I found to help.....
now, por 15 and super clean first, or just slap it on>>>>??????
KEEPING THE CAR QUIET?????..
http://shoptalkforums.com/viewtopic.php ... ht=dynamat
http://www.b-quiet.com/compare.html
http://www.quietcoat.com/html/examples.html
http://shoptalkforums.com/viewtopic.php ... t&start=15
hope that helps......big al surfbug1
- mpdykeman
I just purchased and installed a single 50' role of B-Quiet Extreme ($85) and had enough to do the entire inside of my '69 standard (not including the roof)--I may have enough left over to do a second layer on the front of the floorboards or in the panels.
The stuff went in very easy, sticks almost too good, and I am pleased with the deadning effect it has. With a layer of carpet padding on top I should have a very quiet bug.
- mpdykeman
hey...
just got some weather barrier from home depot....
it was made by gaf...I will post the part number later....
it is very thin....about 1/16 at most 1/8.....of an inch...
and is is about 3 feet maybe 4 feet wide.....
it comes in a big roll....about 1 3/4 square....however that much is....
it was 50 dollars...and it is gravel like on the one side....and sticky on the other....cuts with a knife or scissors....easy to install....
I got it in the roofing section of home depot....
I am going to put two coats of the stuff on under the door panels to start.....maybe I will rip out the rug and the rest of the interior later this summer....too hot in NYC now!!!!!
big al
surfbug1
big al
surfbug1
- vwluvrs
