venturis, air correction and main jets
- 73notch
hi, i have been reading a few older vw performance books and was wondering where i can get larger venturis, bigger main jets, and different air correction jets for my 32 pdsit dual carb setup on my type 3. thanks
You might want to try Gene Berg, as they used to have a lot of Solex parts in stock. Now that CB Performance is issuing their own 32/34 carbs, you might want to try them also. I think somebody once said that Mikuni(sp?)carbs also use the same jets as the solex does, so that might also be another option. I hope this helps.
Bob 65 Notch S
Bob 65 Notch S
