Stock dual carb linkage?
Moderator: Tom Notch
59Bisquik
Post by 59Bisquik » Thu Sep 18, 2014 10:45 pm
I am working on a type 3 engine in a kit car. It has the stock dual carbs and air cleaner setup. The throttle linkage is pretty worn and flexes under use. Is there an aftermarket solution out there or am I stuck building some new linkages? I see a lot of linkages on the internet but most seem for type 1's or if it is for type 3's, it's for aftermarket carbs. Thanks guys!
Re: Stock dual carb linkage?
Post by Marc » Thu Sep 18, 2014 11:31 pm
The factory III linkage is the only setup I'm aware of which will clear the stock air cleaner setup - no aftermarket design would bother to incorporate the bellcrank arrangement that it uses. Does your kit car body offer more overhead clearance (and thus more aircleaner options) than that of a Type III?
Slow 1200
Post by Slow 1200 » Fri Sep 19, 2014 4:01 am
maybe the CSP bellcrank linkage would fit, but that's just guessing, and I'm sure it doesn't come cheap
59Bisquik
Post by 59Bisquik » Fri Sep 19, 2014 7:48 am
The stock bellcrank design is fine, its the actual rods and ends that are worn and flex. I was thinking some aluminum stock and hiem joints would do the trick.
As for the body, it has the same clearance as a standard car. It is an Empi Sportster with a pickup bed.
Max Welton
Post by Max Welton » Fri Sep 19, 2014 8:54 am
The stock setup is pretty simple. With a few hardware bits like you said you can probably just make something serviceable.
Max
59Bisquik
Post by 59Bisquik » Fri Sep 19, 2014 6:24 pm
Ok, thanks guys! I will get to building...
