AAR Adjustment?
Moderator: Tom Notch
Max Welton
AAR Adjustment?
Post by Max Welton » Mon Jun 02, 2014 7:09 pm
What is the correct adjustment procedure for an AAR?
Also, I found that on mine, the shaft does not move smoothly and sticks in the position shown. When the spring reaches ~114ºF (heat-gun and IR thermometer test) the shaft snaps to the closed position instead of moving slowly as I expected.
Max
Max Welton
Re: AAR Adjustment?
Post by Max Welton » Fri Jun 06, 2014 5:19 pm
Done. 8)
Max
aircooledtechguy
Re: AAR Adjustment?
Post by aircooledtechguy » Sat Jun 07, 2014 10:31 am
Max Welton wrote:Done. 8)
So. . . What was causing it to be sticky?? Sludge/dirt build-up, wear??
Max Welton
Re: AAR Adjustment?
Post by Max Welton » Sat Jun 07, 2014 11:35 am
Maybe it got hot and warped? Dunno. It was clean enough.
I put the shaft in a drill and gave it a good hard spin with some cutting compound (ok ... tooth-paste) to let it self-clearance. After cleaning I reassembled it with a little wheel bearing grease and now it's fine. 30 minutes and done.
I do wish it responded more at CHT speed than oil temp speed. But it's simple and good enough.
Max
