Enigne Tins
Moderator: Tom Notch
builtbychevy
Enigne Tins
Post by builtbychevy » Thu Mar 21, 2013 7:16 pm
Do you guys still run the deflectors that go on the underside of the head?(I know they came on a T1 but not sure about T3?)?
My Store: http://www.DirtyRacingAndRods.com
My Blog: http://blog.dirtyracingandrods.com/
If you can't run from John Law with it... It ain't no good!
builtbychevy
Re: Enigne Tins
Post by builtbychevy » Thu Mar 21, 2013 8:56 pm
Max Welton
Re: Enigne Tins
Post by Max Welton » Wed Aug 28, 2013 8:33 am
Yes.
That air dam makes the air go sideways through the fins on the underside of the head.
Simple enough to make if they are missing.
Max
Stray Catalyst
Re: Enigne Tins
Post by Stray Catalyst » Wed Aug 28, 2013 11:17 am
Volkswagen's engineers didn't put a lot of parts on the engine that weren't needed - you'll get better cooling (and a longer engine life) if you have ALL the tine, and ALL the gaskets.
Stray
STOICH
Re: Enigne Tins
Post by STOICH » Fri Jan 10, 2014 4:41 pm
My experience is the engine life will shorten down to mere minutes without those tins in particular
