Oil Shocks
Moderator: Tom Notch
Max Welton
Oil Shocks
Post by Max Welton » Tue Jan 17, 2012 6:34 pm
Last March I put a set of new Cofap oil shocks on my 68 squareback. Worked fine, nice feel.
Over the last few weeks the right front has started making a squeaking noise, particularly in the cold. I don't ever remember this happening with Boges. The local VW shop says he can't get any other oil shock except Cofaps any more.
So I'm looking for a source for Boges, or any other suitable oil shock.
Max
DWP
Re: Oil Shocks
Post by DWP » Tue Jan 17, 2012 7:00 pm
Are you sure it's the shocks? I have had way to many cars do that in the cold. Check all the bushings, rubber shock mounts ect. Try some WD40 on the upper and lower parts.
DWP
As i tell my son, waste money on cars not Girls.
You can always sell the Car.
Max Welton
Re: Oil Shocks
Post by Max Welton » Tue Jan 17, 2012 7:04 pm
I disconnected the upper end of the right shock and gave it a bounce. Noise gone. It's the shock.
Max
aircooledtechguy
Re: Oil Shocks
Post by aircooledtechguy » Tue Jan 17, 2012 10:57 pm
KYB-GR2 shocks are a good, reasonably priced oil shock. I have them currently on my Square and I'm happy with them.
Re: Oil Shocks
Post by Piledriver » Tue Jan 17, 2012 11:40 pm
Monroe makes oil shocks for the T3 front app, Supa found them.
(think they are mentioned in his thread, ~any FLAPS can get them, I got mine from Oreillys IIRC as my local one had them in stock)
Lifetime warranty, made in the USA, amazingly cheap and and work well..
If they ever die I go get a new set from my FLAPS.
GR2s are low pressure gas shocks, and probably not a bad choice, but they list the same one for front and rear, probably not optimal if you think about it.
Monroematics front and GR2s out back would probably be a ~perfect combo.
I still have gas-a-justs on the back and it works, but a bit harsh out back.
I had Gas-a-justs front and rear as a gift from the PO and it was a near-dental-filling removing experience on choppy surfaces.
Max Welton
Re: Oil Shocks
Post by Max Welton » Wed Jan 18, 2012 12:19 am
I've run the GR2s before on my type-1s and the type-3. Too stiff for my taste.
I was able to order some Boge's from ISP. In the next day or so, I'll know if they actually have them to ship. Fingers crossed.
Max
Re: Oil Shocks
Post by Piledriver » Wed Jan 18, 2012 12:53 am
The Monroes are much softer than the GR2s.
Re: Oil Shocks
Post by Marc » Wed Jan 18, 2012 2:09 am
Bilstein makes a lighter-valved model for front and a heavier one for the rear of a Type III, but the either-end offering that most makers have is fine on the front.
Monroe 31089, NAPA 94095, Gabriel 82001.
Max Welton
Re: Oil Shocks
Post by Max Welton » Wed Jan 18, 2012 6:05 pm
Alex at ISP says he has Boges and my order processed.
So this is good. :-)
Max
Re: Oil Shocks
Post by Piledriver » Sun Nov 11, 2012 2:58 am
Did that fix the squeaks?
Max Welton
Re: Oil Shocks
Post by Max Welton » Sun Nov 11, 2012 9:08 am
It did. I have other squeaks, but the saches / boges have been quiet.
Max
