Page 2 of 3
Re: Electronic Ignition Trigger Wheels
Posted: Fri Sep 30, 2011 2:35 pm
by Munchhausen
Max Welton wrote:The angle will be wrong. Might have to make a new TDC mark that can be viewed from the left.
Max
That would be a solution, but maybe its usefuller to find a other position for the sensor than a new position for the timing light to point at?
munch
Posted: Fri Sep 30, 2011 3:53 pm
by supersuk
The angle won't be wrong because you still look at the correct TDC mark on the pulley from the same plane as how you would originally set the timing. It is not skewed to the left or right. The pictures don't show it too clearly. I'll try and get better pics.
Posted: Fri Sep 30, 2011 4:13 pm
by supersuk
Mounting the sensor at another location is a way around that. I've looked at many places, but not much places that offer a lot of room and a clear view for mounting and adjustment. I did mines this way because it was easy access to everything for install, adjustment, and visual checks.
Posted: Thu Nov 10, 2011 12:12 pm
by supersuk
If you look closely, you can see the hole in the fan shroud that allows a viewable access to the pulley to allow timing. In this picture you can't see the pulley, but it is def viewable and timing can be adjusted easily.
Posted: Thu Nov 10, 2011 3:10 pm
by Max Welton
Now I see. Very nice.
Max
Posted: Fri Nov 11, 2011 3:21 am
by Munchhausen
Ah, ok! That looks practicable.
Any experience with higher revs? The typ3 fan-construction is not famous for withstanding very high rpms. Your triggerwheel is far away from the last crankbearing and a imbalance at this place maybe very bad.
Dont misunderstand my asking, iam very happy that somebody is searching for a type3 solution.
munch
Posted: Fri Nov 11, 2011 11:22 am
by supersuk
Not yet, I haven't had a chance to fully install my FI. I don't think 4 45mm throttle bodies would do well on a 1641cc engine. I'm waiting to build up a larger 2 liter motor for the FI install. Almost everything is ready on my car though. Megasquirt, wiring harness, VR sensor, and trigger wheel are installed though. No problems with my 1641cc engine revving to 4500 rpm. My existing motor isn't setup for anything higher.
The design of the trigger wheel is balanced. If you want to take it a step further (which I would recommend), you should have the wheel and pulley balanced together. After installation of the trigger wheel onto the pulley, a very small amount was needed to be removed from the pulley to have it dynamically balanced. I'm sure this was because an uneven amount of metal was removed during the tapping process. The amount removed was very very little so It prolly won't make a difference.
Posted: Sat Nov 12, 2011 7:26 am
by Munchhausen
Do you know if the Trigger wheel is working together with the hall effect crankshaft position sensor from diyautotune?
http://www.diyautotune.com/catalog/hall ... p-479.html
munch
Posted: Sun Nov 13, 2011 12:13 am
by supersuk
I don't see why not? A trigger wheel is a trigger wheel.
Posted: Sun Nov 13, 2011 2:39 am
by Munchhausen
And on the mechanical side? Is the sensor long enough for that particular mounting situation?
munch
Posted: Mon Nov 14, 2011 6:30 pm
by supersuk
looking at the sensor, it is to short to mount it the way I did. You could however mount it at the opposite end (bottom) of the shroud. It'll be pretty hard to do and it'll be close to the header.
Posted: Thu Nov 17, 2011 10:56 pm
by supersuk
Posted: Mon Nov 21, 2011 2:56 am
by Munchhausen
Whats about having the Sensorposition here?
munch
Posted: Mon Nov 21, 2011 6:30 pm
by supersuk
You can install it anywhere you want. I just utilized the hole that was already there.
Posted: Thu Mar 21, 2013 6:17 pm
by builtbychevy
Do realize that assembly will need to be rebalanced.
