Erics 68 Squareback
Eanderson
Erics 68 Squareback
Post by Eanderson »
It will take me awhile to go through photobucket and find all the pictures of my Square, but here goes...
Recent pic
The air suspension
supaninja
Re: Erics 68 Squareback
Post by supaninja »
Here's one I took at a recent show
viewtopic.php?f=14&t=140387
Eanderson
Post by Eanderson »
The front beam was narrowed four inches. Custom 4140 axles were machined to replace the torsions. Bronze bushings and housings were machined for the axles to ride smoothly inside the beam. I removed and retained the outer needle bearings for the control arms. The bulk head was relocated 2" higher and 2" narrower on each side. Custom bag brackets with 1.75" tubing and hiem ends bolt to boxed levers the rotate the axles to raise and lower the car. The bags are tucked away under the area the spare tire used to be located, and a bead rolled sheet metal cover hides them and the solinoids, wires, etc. A custom steering shaft was turned to fit the T3 steering box. Flaming River U-joints were installed to connect the box to the shaft. Everything was then torn down, cleaned, bead blasted, and painted Base/Clear.
The Paint gun is a bleed-off that will lower the car after turning a ball valve to locate air to the trigger!!
More Later 8)
Eanderson
Post by Eanderson »
Painted woodgrain or Faux woodgraining
Eanderson
Post by Eanderson »
Surf board rack
Made from 6160 aluminum
Eanderson
Post by Eanderson »
Custom removable dash. Fabbed from 18 gage steel.
Eanderson
Post by Eanderson »
Frenched-in headlights
Custom formed visor
Eanderson
Post by Eanderson »
A 1915 powers it. CB 044 heads 94mm p/c's. Berg counter wieghted crank. Engle 120 cam, 1.25 rockers, chromoly push rods, 8.5 compression. Italian 44mm Webbers T1 intakes, custom full flow with recessed fan shroud, all AN fittings with braided SS line. External oil cooler Kymco 1 5/8 merged headers with a custom stainless Magnaflow set up.
Noisey straight cut cam gears :twisted:
Eanderson
Post by Eanderson »
Custom breather
Eanderson
Post by Eanderson »
Kymco merged header
Magnaflow with custom SS up and over
Eanderson
Post by Eanderson »
Bead rolled .040 aluminum panels up front
Munchhausen
Post by Munchhausen »
Lunatics with the right tools and to much time :mrgreen:
Great car! I love it!
munch
ALYKAT III
Post by ALYKAT III »
Beautiful ride ! Has to be one of my all time favorite T3s.
Remark
Post by Remark »
The dude has skills!!!!!!!!!!!
Eanderson
Post by Eanderson »
Thanks guys 8) I'm glad Ninja told me about STF! Thanks bro! There are some warriors around here :twisted: I'm liking it!
