As I'm a newbie in the T3 realm, what specifically do I need to inspect for as I go through the frontend?
I know it has to be kept greased well or hard to find/replace parts will wear out, but other than tie rod ends with 1/2" of play giving the car an intense attraction to rain grooves , what particular expensive parts do we check out, assuming all the POs were morons. (usually a safe assumtion, espectially given the 34PICT-3 that was sticking out of a hole in the engine cover... In a SQUAREBACK...)
No...Really. I think I still have the pictures, it was classic, and hammering that bug manifold onto the T3 was fatal for the incomplete cooling system tin... It has a T4 in it now, so NBD)
T3 front end--- What to inspect for ?
- david58
Re: T3 front end--- What to inspect for ?
Rust, worn parts.
Just bumping this up Pile.
- fusername
threads almost a year old, still on the front page, fraida bump wont help you much
http://shoptalkforums.com/viewtopic.php?f=24&t=124108
Thanks, fuser, that and the needle bearins is a good start.
The steering gear box seems to have a little vertical play in the output shaft, but that's adjustable.
EDIT---Adjusted, made a huge difference as expected, looks like it hadn't been touched since `73, still need to check/add gear lube.
Now that I have it in running/driving state it's time to start ripping it apart again!
The sway bar (upper beam) seems to lack zerk fittings... still looking.
Started my Google run, aircoolednut has a nice pagetto read while I wait on a Bentley...
(Should have ordered that months ago)
http://www.aircoolednut.com/erkson/ttt/ ... ystem.html
- Tom Notch
The upper grease fitting is just behind the beam to body mount bolt head, buried under grease. There is a hole in the beam to frame clamp piece that it sticks through. Hope that makes sense......
Tom
Tom's Old VW Home
DVKK
DSD, dark side disciples
Tom's Old VW Home
DVKK
