Time for the Brembo and IRS on the rear ( updates)
well i have started the brembo conversion on the squareback now
hubs machined
bearing adapter and sleeve using vw inner and 944 outer
vw race installed
vw inner bearing and 944 outer bearing
test fitting hubs and rotors
test fitting calipers to see what i need to made for a adapter to mount them
hubs machined
vw race installed
- notched
Re: Brembos going on the square now
Are the hubs 944? Do you have any pics of the backside and how you mounted the calipers?
yes the hubs are 944... the rotors are from a 993 got a good deal on a set of front and rear . the only problem with the front one are. That they are 32mm thick. SO being they need to be resurfaced anyways had them turned down to 28mm and they slip in to the calipers now... I will take some more pics soon... still working on the caliper mounting. looks like i just have to relocate one mounting tab or weld on a extra mounting tab to mount the calipers. As soon as i get it done i will add more pic. of how i mounted them. right now i making sure i do not run into clearance issue with my wheels look like the calipers are going to be close.
- notched
Looks great so far!
made the mounting bracket for the calipers today. I cut the mounting tabs off a set of 944 spindles trimmed them up and welding them to my stock typ3 spindles. test fitting everything on one side today...
- Rex Surewood
Looks good.
Here's how I did mine..
Turned down a pair of old, stock discs - turned the disc-part down, so I basically had the hub only. So standard bearings could be used.
Then used 944 Turbo rear discs. As far as I recall they are 295x20,4 mm, and they slide right over the homemade hub.
Then I used the original upper caliper bolt hole, and moved the lower one a bit. I used the 72-> spindles for this, as the bolt spacing is the biggest.
Works like a charm!
Works like a charm!
got the front brakes done now on to the rear
Now, don't you look nice?
- Roverjosh
Dude, the wheels look fantastic! I love phone dials... good choice.
Josh
We come from dirt,
We return to dirt,
Circle of life, man.
We come from dirt,
We return to dirt,
- supaninja
sweet dude, this is definitely on the todo list for the notch.
viewtopic.php?f=14&t=140387
- Roverjosh
Any progress to report on the brake upgrade? I am just curious.
Josh
We come from dirt,
We return to dirt,
We come from dirt,
We return to dirt,
- Tom Notch
These are both pretty kool ways of doing this conversion.
Phone Dials and T3s were made for one another, nice looking ride!
hmmmmm...........
I already have 4 wheel discs, but.....maybe.......an............upgrade..........
eerrrrrghh
No! More! Projects!
hmmmmm...........
eerrrrrghh
No! More! Projects!
Tom
Tom's Old VW Home
DVKK
DSD, dark side disciples
Tom's Old VW Home
DVKK
Sorry been really busy with other parts of the Car. rounding up the parts for the Irs conversion on the rear and paint and body work . Hopping to get started soon on the rear. Once the irs goes in and with the 944 alum arms the rear brembos are just a bolt on.
- supaninja
I hope those Al arms fit, I know the later al arms add a lot to the width.
