oil ring collapse
vanbuzz
oil ring collapse
Post by vanbuzz »
just had 2.0L 1995 rebuilt, drove it 3000 miles, trouble i had is that it would go 1qt/100miles. took motor back to shop, they showed me that all the oil rings had collapsed. Any comments or suggestions that would cause such a problem :?:
Marc
Post by Marc »
Were the pistons/cylinders replaced or were the originals cleaned/honed/reringed? If the latter, how much taper in the cylinders?
What style of oil ring? If 4-piece, were the expanders installed correctly, with their ends butted and not overlapping? Were the rings used the correct depth for the pistons? Were you given instructions on how to drive during break-in that included avoiding sustained operation at any steady speed, and did you follow them? Did the engine run especially hot?
http://www.aa1car.com/library/2003/cm90330.htm
http://www.hastingsmfg.com/ServiceTips/ring_types.htm
http://www.hastingsmfg.com/ServiceTips/ ... depths.htm
vanbuzz
Post by vanbuzz »
machining was done by professional, was bored 20 over the rings and pistons came as a kit. two with corragated expander between. drove it hard 3000rpm and let it come down, then up again.
I have seen it on cast iron single piece ones... bald in a few thousand miles, and have everything else look/check out perfect on a couple of occasions. (COFAP both times)
I try to only buy German rings... It's not worth the time or money to use the Brazilian/Mexican rings sometimes.
