Megajolt user outputs to control boost?
Moderator: Tom Notch
Krochus
Post by Krochus » Sun Aug 05, 2018 10:18 pm
For whatever reason a clear overview of a 12v solenoid controlling boost eludes me in terms of electronic operations.
I get how the mechanical aspects work
But if I use a 3 port 12 v solenoid can one of the user outputs on the MJ unit with the appropriate parameters be used to hold my boost pressure to a predetermined limit?
Secondary will the “on off” nature of such a setup pose any issues and perhaps create a surge loop as the boost builds, wastegate opens, boost drops, wastegate snaps shut?
Jadewombat
Re: Megajolt user outputs to control boost?
Post by Jadewombat » Mon Aug 06, 2018 12:37 pm
I'm wondering about some of the outputs also. I'm doing a MJ install of a friend's Vanagon currently. Did you post to the forums at ASL?
https://forum.autosportlabs.com/
