Mega Log Viewer Graph Scale
Moderator: Tom Notch
Owen Snell
Post by Owen Snell » Sat Sep 24, 2016 2:09 am
I've set up the MLV graphs for fine tuning the VE table and have actual and target AFR on one graph. The default setting is for the software to scale the Y axis independently for each of the traces, so because the actual AFR varies a lot more than the target AFR, the scales are different, so that that the 'overlay' is meaningless in terms of relative values between the graphs. Is it possible to fix the Y axis for 2 variables so they both show at the same scale?
jhoefer
Re: Mega Log Viewer Graph Scale
Post by jhoefer » Sat Sep 24, 2016 10:24 am
Calculated Fields -> Fixed Field Min and Max -> Add fixed field min and max.
Owen Snell
Post by Owen Snell » Sun Sep 25, 2016 6:52 am
Thanks a lot, sorted now.
