Megasquirt Injectors Bank 1 and 2 67 Beetle
I'm just getting ready to wire my injector plugs up and wanted to know the way to do it.
Does Bank 1 do one side cylinder 1,2
Bank 2 the other side 3,4
or 1,3 for one Bank and 2,4 for the other Bank.
J
J
Re: Megasquirt Injectors Bank 1 and 2 67 Beetle
I wired mine according to Mario's wiring diagram.
As far as I can tell it's 1,2 and 3,4.
He does have 1,3 and 2,4 listed as alternating squirts so you could probably try it either way and see which gives better results.
How are you splitting the wiring though? I got one wire for bank 1 and one for bank 2... Wondering how to neatly do it ...?
I'm running 4 wires, pin 32,33 for one bank and pin 34, 35 for the other as outlined from MS2 build.
Hmmmm maybe I need to re look!
think crank position at TDC
bank1 : 1 & 3
bank2: 2 & 4
bank1 : 1 & 3
bank2: 2 & 4
I'm running mine 1&2 and 3&4 and it works....
It will work for most definitions of works.
Alternating may not work as well.
Make sure to turn semi-sequential on for consistent injection timing at least.
Yes but ITBs will never be perfect...? Works well enough for me:)
Turn on semi sequential you say? Will read into that, cheers!
- gtmdriver
The Beetle firing order is not the same as an inline 4 cylinder engine.
It is
1-4-3-2
so you should wire the injectors so that
Bank 1 is cylinders 1 & 3
Bank 2 is cylinders 2 & 4
It is
1-4-3-2
