Another microsquirt install
- 55superbeetle
Figured I would share my latest build. This is a friends car that used to have 48 IDA's on it. It ran 12.90's with the carbs but didn't see the street as much as he liked. He is kinda over drag racing it and just wants to drive it more often, so it was decided that efi would be a good direction to go. I know getting rid of the ITB's is most likely going to loose some power but not having to deal with linkage was worth the sacrifice to him. Of course it still had to look good too.
Anyway it's running the newest mircosquirt, cb manifolds that I welded plenums too, crank trigger, subaru coil with internal ignitors, bosh idle valve, and a flex fuel sensor. I added a small fuel sump to the stock tank and put the regulator and flex fuel sensor up front so I only had to run one line to the rear. I have done a bunch of megasquirt installs but this was my first on a bug motor, kinda surprised to see how little vacuum it makes with the common plenum and fk8 cam. It had a nice little idle lope now I used the deka 600cc injectors which are physically ridiculously small, with the intent of adding a single dry shot of nitrous at the throttle body if he ever wants to make it faster.
Anyway here are the pics
- juki48
Re: Another microsquirt install
nice clean build. thumbs up on the suby coil pack, I've been happy with mine so far.
Riley
74 Ghia 2276 Turbo MSII Extra
67 Beetle in restoration
Manx Style buggy 1600 stock
How does the one line plumbing layout work out? Is the engine "dead headed" with no loop?
Steve
My Baja Build
My Baja Build
- 55superbeetle
Yeah I have used the micro of a few subaru swaps so it made sense to use it on this motor, even used stock subaru wires.juki48 wrote:nice clean build. thumbs up on the suby coil pack, I've been happy with mine so far.
Yeah just dead headed at the rails. Seems weird but most modern cars have return-less fuel systems now.Steve Arndt wrote:How does the one line plumbing layout work out? Is the engine "dead headed" with no loop?
Dumb question but is there a gauge in tunerstudio that shows ethanol content? I can't seem to find one, assuming it exists.
Is your regulator referenced to MAP up front or running static P?
Steve
My Baja Build
My Baja Build
- 55superbeetle
Static, it's actually just a stock type 3 regulator.
- 55superbeetle
Also just updated to the newest firmware, it has all the e85 percentage and correction gauges in it so solved that mystery.
- Corysvdub
Do you have a pic of how you have the flex fuel sensor hooked up? What sensor are you using?
Type 3 Subaru powered EJ25
- Chris181
- 55superbeetle
I will have to get some pics, it's just plumbed in the return line. I got it off a 2000 flex fuel taurus.Corysvdub wrote:Do you have a pic of how you have the flex fuel sensor hooked up? What sensor are you using?
I used a 3" tube for the sump and 5/16 tubing for the feed/return. Having everything mounted to the tank makes it easy to service and keeps it halfway simple. I have done a bunch of bugs this way, you can go way deeper with the sump if you want to. Only down fall as some of my friends have found out, is that there is no warning of low fuel. Once you're out you're out, not even a hiccup.
- Chris181
really a nice ensemble work, clean, simple, effective .
- fastback
very clean setup.
how does it run with this setup`?
Have a newbie question here. I know the principle behind the fuel systems with a return line (loop) and the dead-headed systems, but never really learned which one was better. Does the dead-head system put more load on your fuel pump if there is no return? From what I have read, in an looped system, a majority of the fuel you are pumping goes back to the tank and only a fraction is actually used by the injectors.55superbeetle wrote:Yeah just dead headed at the rails. Seems weird but most modern cars have return-less fuel systems now.Steve Arndt wrote:How does the one line plumbing layout work out? Is the engine "dead headed" with no loop?
I just haven't seen much on dead-head systems on this forum. I like the simplicity of the design, but wasn't sure how ideal that setup was. Any information from those with greater knowledge would be cool to see.
His system doesn't dead head the pump. It just has a very short loop up front that is regulated, with the fuel rails Tee'ed into that loop ending up at a dead end at the rails.
I'm curious how it works out and why we I haven't seen it done before.
Steve
My Baja Build
My Baja Build
So basically the pump bleeds off excess pressure with a small loop to the tank? In this case, would the pump basically work like it had a FPR built in? Thats really cool. Your loop is basically contained completely under the tank and then you are just running the needed/regulated pressure to your fuel rails?Steve Arndt wrote:His system doesn't dead head the pump. It just has a very short loop up front that is regulated, with the fuel rails Tee'ed into that loop ending up at a dead end at the rails.
Rad.
