Pleated paper air filters?
- MinamiKotaro
I noticed a tear in one of my Dellorto air cleaners, so I need some new ones. I'll go K&N if I have to, but I'd rather have a standard paper element-type filter. Does anyone have a part # for one that will fit a Dell-type air cleaner assembly?
'67 Beetle, 2276
MS-1 v3.57
MS-1 v3.57
Re: Pleated paper air filters?
There was mention of one in the offroad forum a while ago. I would also like to know. It is supposed to be a direct fit for standard IDF size oval filters.
Steve
My Baja Build
My Baja Build
- sideshow
There is at least one ?dodge mini van? pre 1990 that has the same enough shape, but much taller.
Would fuel standoff wet the paper????
- Devastator
You might also consider a dryflow filter from AEM. I'll never use a K&N again.
Devastator's Build Thread
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
- MinamiKotaro
I guess that's what I'll do. I have been unable to find a paper filter of the right size that's oval or even a round one that could be smooshed to the right shape. Thanks for the heads-up on the AEM, I hadn't heard about those.Devastator wrote:You might also consider a dryflow filter from AEM. I'll never use a K&N again.
'67 Beetle, 2276
MS-1 v3.57
MS-1 v3.57
I checked the AEM site. They don't have anything in IDF/DRLA size.
Steve
My Baja Build
My Baja Build
- Devastator
Do you have the dimensions for a round one?
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
This is the standard oval IDF/DRLA filter.
http://www.knfilters.com/search/product ... rod=E-3341
Product Style: Oval Air Filter
Air Filter Shape: Oval
Height: 3.313 in (84 mm)
Inner Wire: No
Inside Length: 6.125 in (156 mm)
Inside Width: 3.625 in (92 mm)
Outside Length: 7 in (178 mm)
Outside Width: 4.5 in (114 mm)
Top Style: Open
Top Material/Finish: None
Filter Material: Cotton Gauze
Flanges: None
Package Contents: 1 Air Filter
Package Quantity: 1
Inner Wire: No
Top Style: Open
Flanges: None
Package Quantity: 1
Steve
My Baja Build
My Baja Build
- Devastator
I don't see the circumference on there anywhere, which would be needed in order to calculate the "round" equivalent.
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
I fought this battle awhile back...
AMSOIL used to make them in their synthetic washables, but they were discontinued.
Perhaps you might find some old stock?
Uni may have something.
If all else fails, clean the torn spot with brake cleaner and blow dry...
spooge some shoo-goo into the torn spot and wrap the K&Ns with oiled Uni outers.
More or less uses the K&Ns as internal supports for the UNI, but at least they will be good for something.
Along those lines, the Oz-based division of UNI makes some interesting setups, consider what is possible with slabs of foam, glue, some wire and a welder.
http://www.uniflow.com.au/contents/en-us/d136.html
They can probably make the important foam bits to spec on a custom basis at a quite reasonable price.
(The US website is far less interesting, but they DO list outers for Weber sized K&Ns)
- Devastator
The last time I tried looking for a DRLA filter that wasn't a K&N, I ended up putting turbo hats on the carbs and pipinig them to a filter housing located elsewhere.
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
As discussed elsewhere, that is a good power loser for N/A.
The offroad forum guys had paper pleated IDF direct drop in #. We just need to find the info.
Steve
My Baja Build
My Baja Build
This is annoying:
http://www.ebay.com/itm/RPM-Dual-Pod-Fo ... 56&vxp=mtr
Maybe we need to ask UNI to make filters for IDFs etc.
Somebody makes supports for weber ar cleaners... cheap even.
These are for Weber wire mesh filters, but I can see it as a good first pass as a support for a Uni setup.
http://www.ebay.com/itm/WEBER-600-SERIE ... 51&vxp=mtr
Matching(?) NO-oil foam element, not sure if worth a darn, but ...
http://www.ebay.com/itm/WEBER-CARBURETO ... 6329&rt=nc
No one should be forced to buy gauze filters.
They are marginal on actual racing vehicles as they don't filter jack, and ring seal is the #1 power adder.
These would actually work if you could secure it to the baseplate well, but come from the UK, not sure the free shipping is valid
http://www.ebay.com/itm/Weber-40-DCOE-C ... 4f&vxp=mtr
- Soul
If you wanted to go with a UNI filter the one below should work.
http://www.ebay.com/itm/Uni-Air-Filter- ... f5&vxp=mtr
