VFR800 Questions
Cragrobbo
VFR800 Questions
Post by Cragrobbo »
Hey guys, I have read all the threads on here about carious injection systems. Still a little contused.
I am really liking the VRF800 route, however I see no MAF or MAP sensors on them?
According to miniman I use an Accumulator (I am unsure what that is)
DO I need any other sensors, like Lambda or air intake, a trigger wheel?
I am still learning and if I go the route of Bike carbs what else do I need with them as far as sensors?
Craig
Max Welton
Re: VFR800 Questions
Post by Max Welton »
The MAP sensor will be external, not part of the TB. If you are using Megasquirt, the map sensor is mounted in the ECU container. You just run a vacuum hose from the manifold to the ECU.
Max
Max Welton
Actually, I think Pile and Mini are giving you great info over in this other thread. You should continue the discussion over there.
http://www.shoptalkforums.com/viewtopic ... 2&start=15
Also, there is a lot of good reading over at http://www.msextra.com/.
Max
Cragrobbo
Post by Cragrobbo »
Thanks max. Yeah pile and miniMan have been a fantastic help very much in their debt.
I was hoping to get a clearer understanding of bike itb specifically but I think I'm getting there and I hope to start buying the parts this payday
Dale M.
Post by Dale M. »
Do not let the fact that its a bike TB confuse you... TB's are mainly (in theory) just a air flow control valve, with a sensor on shaft to tell ECU how much its is open... And a place to mount injector...
Dale
Cragrobbo
Post by Cragrobbo »
Dale M. wrote:Do not let the fact that its a bike TB confuse you... TB's are mainly (in theory) just a air flow control valve, with a sensor on shaft to tell ECU how much its is open... And a place to mount injector...
Dale
Understood, Thanks.
Still getting my head around the required sensors for the system.
From what the guys said in the other thread I think I have narrowed it down to:
Crank sensor(for RPM and firing I presume?)
Accumulator for the Throttle bodies which will then goto a MAP sensor
Lambda Sensor (Wideband)
Air temperature sensor
I was also Suggested a coolant sensor but wherre does this attach on an aircooled motor?
Dale M.
Post by Dale M. »
Dale
Understood, Thanks.
Most Coolant sensors are to tell ECU when engine has warmed up enough to adjust back idle richness to desire lean for proper idle air/fuel ratio... Most people use sensor off the head or crankcase which reads oil temperature or you can add one on/near exhaust flange so as engine (exhaust) heats up it fools ECU into thinking the "coolant" is up to temp and do its thing and adjust air/fuel mixture control.... Might be less confusing to just drop the word "coolant" out of the wording.....
Dale
Cragrobbo
Post by Cragrobbo »
Dale M. wrote:
Dale
Understood, Thanks.
Dale
Gotcha, that makes seance now.
Craig
