I received and installed my new fuel injectors today. It was about three times as difficult as it needed to be because I was too stubborn to remove the throttle bodies, so I had to work with almost no space and the air cleaner studs digging into my forearms.
Anyway, after I installed them and got everything put back together, I of course started the engine to see if the new injectors made any difference to my low-RPM miss problem. I smelled gas and the fuel gauge needle was moving toward "E" so fast I could watch it go.
"OH $#@!"
I quickly shut down the car and hopped out to inspect everything. Seems fuel is spewing from somewhere around #3. I hope the cause is merely that I didn't get the AN fitting tight enough. I'd hate for the hose to have developed a rip or who knows what else.
For the record, I got these injectors. They are exactly the same length as the Accel ones I was using, so no adjustments to the hold downs necessary. $155 for the set of four.
- Volky
Re: $#@!
I know how it feels. Every time I have to take my webers (throttle bodies) out for a spark plug change or other mod I think about it. It's always a hassle and the worst part is either you #%^* up your forearms with the velocity stack or go the extra mile and take it off.I received and installed my new fuel injectors today. It was about three times as difficult as it needed to be because I was too stubborn to remove the throttle bodies, so I had to work with almost no space and the air cleaner studs digging into my forearms.
I was considering cutting the sides and buying the stainless steel plates someone sells somewhere I saw in the Internet.
1970 VW Beetle with 2109cc turbo with MS-II v3.0, wasted spark, electronic boost controller, dual table, launch control and 3.88 tranny. All done by me... t03 running 48lb. Injectors, Intercooler, Water/Meth injection at 15psi.
- TouringBubble
Re: $#@!
Could also be the o-ring at the rail. Working in a tight space it's easy for one to get snagged without you knowing. Good luck on a quick fix!
Follow my SCCA Rallycross build on Facebook.
Dirty '73 Beetle. 2109cc with way too much intake.
Power numbers to come.
Sponsors: Satellite Racing - Defined Performance
- MinamiKotaro
Re: $#@!
The AN fitting was only finger tight. Guess I was tired and frustrated enough last night to overlook tightening it. On the downside, my low-rpm miss is still there. I was really hoping it was a bad injector.
'67 Beetle, 2276
MS-1 v3.57
MS-1 v3.57
- Devastator
Re: $#@!
Well, at least that side of the engine is clean for that upcoming compression check.
Devastator's Build Thread
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
