Vanagon Intake Plenum - single throttle body versus four
luftvagon
Post by luftvagon »
How much of a restriction is the stock vanagon intake plenum and intake runners?
For my next project, i am thinking of welding and machining the intake chamber in order to relocate the throttle body to the top of the intake chamber. The chamber will accept GM Vortex throttle body.
Should I not bother? Are the intake runners cumbersome restriction? Should I be better off going with four throttle bodies mated to a straight intake runner?
1981 Volkswagen Vanagon Westfalia - air-cooled Type4 1970cc CV (hydraulic lifters, 42x36 valves, stock cam, microSquirt FI)
1993 Ford F-250 XL LWB Extended Cab 7.3L IDI
Jadewombat
Re: Vanagon Intake Plenum - single throttle body versus four
Post by Jadewombat »
What is the TB/butterfly size? A P+P job never hurts. Size is not the only thing that matters and bigger is not necessarily better. Changing single TB it is very easy to sacrifice driveability/throttle response (get it wrong). Manufacturers spend millions of dollars and tons of research getting the right TB to match the intake runners.
I had access to a flow bench years ago and tested a lot of different TBs and carbs. What surprised me was taking the biggest Jetta TB I had would slightly less flow than if a large intake pipe was added on it. You would think that the TB having nothing on it would flow more (open air), but the numbers did not say this. The intake pipe channelled and sped up the air flow.
tencentlife
Post by tencentlife »
Vanagon 2.1 TB throat size is 50mm, 1.9 size is 45mm.
MarioVelotta
Post by MarioVelotta »
I'm working on this project. A 2.2 wasser, adding a SC12 Toyota supercharger. Replacing the factory plenum with a 4" and using a 55mm throttle body.
[email protected]
gearheadgreg
Post by gearheadgreg »
That's awesome, man!
Dealer for Alloy Wheels & Period H4s and Fog/Driving Lights
http://www.greggearhead.com
aircooledtechguy
Post by aircooledtechguy »
O.K., I'm throwin' the BS flag on that one Mario. You CANNOT go teasing us like that with one measly incomplete photo of motor porn like that; it's just not nice!! :wink:
MarioVelotta
Trying to get the flows worked out. This was one of the first models.
[email protected]
Steve Arndt
Post by Steve Arndt »
I was just saying the same thing earlier. He is playing with mini bikes instead of blowing the wasser.
MarioVelotta
I need to take a break somehow! I'll get back to it, don't you worry :)
[email protected]
