In the pursuit to provide super clean installation of modern EFI & Ignition systems, there has been much discussion about trigger wheel sensors. While visiting with my dad today, he was showing of his latest RC plane with, I noticed this...
This sensor is about as big as a quarter, and super low profile. I don't know if it would work in high heat environments, or is the proper voltage. It did require a "flying magnet" which was mounted on the fly wheel, which is visible at about 2 o'clock. It has three wire connection, and based on some specs that I found on the ignition module, uses a 4-7 volt power supply.
Just thought I'd share.
Tiny Hall Effect Sensor
- CBDZ
My Car Details:
Fiberglass Buggy on 1973 Chassis.
1904 cc
Megasquirt (MS1 with 3.57 board) Fuel Injection: German Intake Plenum, CB Performance End-Castings, Ford Escort Throttle Body with custom Adapter, MS controls Wasted Spark Coil Pack
1904 cc
- Prtexx
Re: Tiny Hall Effect Sensor
Heres another example of an easy inexpensive setup, works with 5 volts 2 wire. Subaru rear tranny speed sensor.
Steve
67 VW roadster
36 Buick 3 window coupe blown 350
87 Syncro 2.5 Subaru
84 Westy
77 Westy 2.5 5 speed
FB VW Subaru Conversions
67 VW roadster
84 Westy
There's a similar thread a few months ago, found one miniature gear tooth sensor (with rare earth magnet built in) that was ~5mmx8mmx8mm IIRC.
First hit on Google for "miniature gear tooth hall sensor"
http://www.allegromicro.com/Products/Ma ... TS616.aspx
It needs to be embedded in epoxy or such and wires added, but it's a complete unit.
It's under $5 in onesies.
