Cb Efi Problems
rich74310
Cb Efi Problems
Post by rich74310 »
Hi Guys,
Wondering if you can help. I have a Cb Efi system it a quick tune. I am having some major problems with it. Basically i got it running on the car and now it runs for 20min then stops. It just pumps fuel alll the time. I have changed the coil,plugs,leads,rotor,cap plus checked all connections to the unit. Checked the grounds,battery cables,battery,alternator etc.
I was driving it the other day and it just stopped. Left it for the night and it started again no probs, ran for twenty min and stopped, then wouldnt start. I reflashed the tune and it started for 20min then stopped. Tryed eveything but it wont go now at all. Im at a loose end with it as i paid up loads of money to buy the kit and have only used it for 2000km.
The other thing is that when it was running it sounded like a misfire as it came on boost and it does it all the time. Checked the timing etc but it is now driving me mad.
I am running 42lb injectors with a t3 turbo.
Cheers
Guys
Rich :(
luftvagon
Re: Cb Efi Problems
Post by luftvagon »
Sounds like something is getting warm and stops working. Can you check fuel pressure when it stops working?
NO START = FUEL? SPARK? AIR?
Do you have spark?
Do you have fuel?
1981 Volkswagen Vanagon Westfalia - air-cooled Type4 1970cc CV (hydraulic lifters, 42x36 valves, stock cam, microSquirt FI)
1993 Ford F-250 XL LWB Extended Cab 7.3L IDI
luftvagon
Re: Cb Efi Problems
Post by luftvagon »
post a picture of your computer wiring in relationship to the engine as well...
gearheadgreg
Re: Cb Efi Problems
Post by gearheadgreg »
Is your fuel tank correctly vented?
Dealer for Alloy Wheels & Period H4s and Fog/Driving Lights
http://www.greggearhead.com
MarioVelotta
Re: Cb Efi Problems
Post by MarioVelotta »
What is your IAT? Are you intercoooled? Does it go lean?
[email protected]
rich74310
Re: Cb Efi Problems
Post by rich74310 »
Got fuel, got spark, got air. I think that lamder may be to blame. Got it started for about five min af meter on lean. Pulled the collector off and it was full of fuel.
Going to pull the engine out, rebuild it and put it all back to fresh.
